Projects the '27 Roadster saga
Discussion in 'The Hokey Ass Message Board' started by Paul, Jul 20, 2010.
  1. Paul
    Paul
    Editor
    thanks BT, my pleasure
    rear shocks went in today,
    I had this old tube shock kit for 1939 Ford front kicking around for a while
    very compact, figured they should fit the bill fine.
    chopped the tower brackets and welded the top mount to the frame,
    then cut some lower brackets from what was left of the tower,
    bolted the shocks in and tacked the lower brackets in place,
    took the shocks back out and welded the brackets to the wishbones,
    let it cool to the touch and bolted the shocks back in.
  2. Paul
    Paul
    Editor
    outside shots..
  3. alchemy
    alchemy
    I like the shocks hidden in front of the axle.
    Paul likes this.
  4. Paul
    Paul
    Editor
    More often than not,
    If the end result is to imply simplicity,
    the more thought in planning
    and effort in execution is required..
    Spent half the day on something so simple
    it should have taken five minutes..
    Maybe that's what I like about it
    brEad and Tim_with_a_T like this.
  5. Great work Paul. A late friend said "simple is hard".
  6. Paul
    Paul
    Editor
    That's what I'm talking about,
    Your friend was able to refine my three paragraphs
    Into three simple words.
    brEad and Atwater Mike like this.
  7. justabeater37
    justabeater37
    Great idea on the rear shocks. I have those same brackets kicking around here someplace. I am going to copy this great idea. I will give you credit for the idea though. It saves me a great deal of head scratching on mine. Now I just need to figure out the cantilevered front shock mounts.
    Paul likes this.
  8. Paul
    Paul
    Editor
    made a few body to frame mounts today,
    eight points of connection,
    should be enough.
    here's a few pictures
    this is a typical fab scenario
  9. Paul
    Paul
    Editor
    same same..
  10. Paul
    Paul
    Editor
    front and rear
    dubie likes this.
  11. Paul
    Paul
    Editor
  12. 51box
    51box
    from MA
    Great build, lots of good ideas
    oliver westlund and Paul like this.
  13. Make sure you leave room with the mounts so you can shim the body, it helps the doors to open and close. :) JW
    Paul likes this.
  14. Paul
    Paul
    Editor
    I only allowed for one eighth shim at the firewall mount but three eighths on the rest.
    I fit and welded all with solid steel shims, replacing the steel shims with rubber after cool.
    Of course these too are temporary as the whole car is about to be completely blown apart for final finish.
    I hope to have the chassis done and finished soon, the body may have to live in a semi finished state for a while as I'm getting anxious to have a car on the road this summer.
    brEad and 26 T Ford RPU like this.
  15. Paul
    Paul
    Editor
    modified the trunk floor I had made earlier,
    when I made it the plan was to run the exhaust outside and shocks behind the axle.
    now that those plans have changed some of the work in place needed slight alteration.
    the two boxes I had sunk into the trunk floor (battery and what-not) needed to go,
    they conflicted with both exhaust and shocks.
    and some minor changes to the substructure of the floor needed adjustment,
    now it fits fine.
    I may have to eliminate the two trap doors,
    they serve no purpose now, unless I make some smaller boxes for storage.
    and I will have to find a new location for the battery,
    maybe under the passenger's feet?
    I'd really rather not take up any trunk space.
    brEad likes this.
  16. hasty
    hasty
    Good to see this build again - Always enjoy your posts
    Paul likes this.
  17. Paul
    Paul
    Editor
    Thanks hasty
  18. Paul
    Paul
    Editor
    final tear down today,
    well hopefully final for the chassis anyway.
    body off, engine out,
    engine hanging with it's Olds buddies one last time
    bare frame,
    and frame clamped to the frame table
    ready to finish up the last bit of welding
  19. flatford39
    flatford39
    Holy cow...you are the Old('s) Man.
    Paul likes this.
  20. bct
    bct
    Your methodical build style is inspiring. That tub looks solid.
    Paul likes this.
  21. Paul
    Paul
    Editor
    Thanks guys,
    All major welding done,
    just a few small holes to fill.
    And a few more to drill and tap.
    If the weather holds maybe paint tomorrow..
    cactus1 and kidcampbell71 like this.
  22. Paul
    Paul
    Editor
    break in the weather today,
    rolled the frame outside and started prep work
    grinders, wire brush and safety gear
    you only have so many lungs, ears, eyes and skin and you might need them later.
    a good mop with phosphoric acid will take car of what little "surface" rust is left.
    paint will have to wait for tomorrow
    then finally maybe start reassembly
    brEad likes this.
  23. David Chandler
    David Chandler
    I have always enjoyed your builds. I wish I half of your skills.
    Good luck!
    Paul likes this.
  24. Paul
    Paul
    Editor
    Got some paint on the frame today,
    Coat of red and a coat of semi gloss black.
    Using Zero-Rust brand here.
  25. another step closer Paul..............looking good
    Paul likes this.
  26. RainierHooker
    RainierHooker
    from Tacoma, WA
    Go man go. You've got more than a month before the Billetproof Drags. Plenty of time...
    Paul likes this.
  27. Looks good. was the red coat a primer coat?
    Paul likes this.
  28. Paul
    Paul
    Editor
    Zero-Rust is a one step primer/paint, I went two coats because I wanted the extra protection and two colors because I didn't have enough black to do it all in one color.
    Plus now when it gets chipped I get to see red. It looks a lot like the old "red lead" primer.
    Still on the fence about the semi gloss, it may get a coat of gloss black too..
    brEad likes this.
  29. haha fair enough! Thank you for the info. Looks good!
    Paul likes this.
  30. Paul
    Paul
    Editor
