Technical th 350/ powerglide flex plates
Discussion in 'Traditional Hot Rods' started by twostickmutt, Nov 23, 2020.
  1. twostickmutt
    twostickmutt
    going to do the power glide to TH 350 swap this weekend in the coupe and was wondering if the flex plates were the same for both trans. thanks and everyone have a safe and great thanksgiving !
  2. 1934coupe
    1934coupe
    Yes they are the same.
    Pat
  3. squirrel
    depends which powerglide, and which TH350. I think you'll find that early cast iron powerglide flexplates might not have the small bolt pattern drilled.
    Just check to make sure, before you bolt in the transmission.
    LOU WELLS likes this.
  4. twostickmutt
    twostickmutt
    thanks pat
  5. twostickmutt
    twostickmutt
    thanks jim
