TECH -Pot Metal+Fiberglass+Washing Machine=Flip Out Taillight /Gas Fill
Discussion in 'The Hokey Ass Message Board' started by Cody Walls, Sep 6, 2011.
  1. Cody Walls
    Cody Walls
    So what I'm showing you guys is how I build a flip out taillight/gas fill and latch set up for a 57 chevy cameo pick up ,I've built these set up on past projects of mine and they worked out great .This two point hinge set up can be used on other application as well, I got the hinge idea from my washing machine it opens the door out and open at the same time and I thought it would work perfect on a taillight , so I ran into a lot of obstacles when building this specific setup for the cameo , one was verry little room for the hing to move correctly, two the taillight housing is made out of pot metal , and three the bed side are fiberglass and there's no real good place to mount a strong hinge from , so bare with me and I'll get photos up as soon as possible.
  2. Cody Walls
    Cody Walls
    So here is what I have to work with the taillight out and just a fiberglass hole
    Since there is a ledge there I'll make a pattern of the inside contore of the bed side
    The reason why I'm making a pattern is so that I can make adjusment before I make the inner structure out of steel .
    here is the patter transfered to steel I chose 10 Gage since it thick and sturdy and I won't have any problems down the road with the hinge being mounted to something flimsey
    I welded a flange to the top of the plate so it so it can all be removible and bolt threw the fiberglass flange .
    Take notice to the bend in the plate to fit the contore of the inner bed side.
  3. Cody Walls
    Cody Walls
    So this is where I got the hinge idea [​IMG] just notice how it just doesn't swing open
    It swing out and open giving the door more room to move since it's pivoted in two spots
    So here's the stare of the hinge out of paper , I had to try a couple of different sizes and arches of the swing to get something that was small and compact but yet still open up and out.
    Here's the hinge, i didn't get to show the process of how I made the hinge since my camra died but I'll just explain the process I just took the paper pattern of the hinge and transfered it to a peice of 10 Gage twice to make a top and bottom , then I just filled in the center with 1 in strap steel bent to the shape of the top and bottom peices and welded them all together and grounded down all of the welds to make this hinge , I'm using door pins and bushings that were laying around the shop for the pivot points
    [​IMG][​IMG]
  4. Cody Walls
    Cody Walls
    So I welded two tabs to the out side edge of the mounting plate for the hinge to mount to
    Now for the taillight itself. Since it's pot metal I can't weld tabs to it for the hinge. So I decided to make a metal backing plate to mount the housing and hinge to
    Here it is in metal form, I made this out of 10 Gage I drilled holes in the housing and threw the plate so I could bolt the housing to the plate
  5. speed-kings
    speed-kings
    Looks good. I was trying to figure out a way to put the filler behind a tailight.
  6. Cody Walls
    Cody Walls
    So once I had this part done I new when the hinge swung open that the backing plate needed some reinforcement so I made another plate to attatch from the inner steel bed to the backing plate
    Here's the pattern I came up with
    In steel form
    Just a view from the backside
  7. Cody Walls
    Cody Walls
    So here's the taillight all bolted up and going threw it's range on motion
    The spring on the bottom of the hinge keep the light from hitting into the bedside when fully open
  8. i have also been pondering a way to make this work, thank you for this tech post, i just wish i could have seen how you decided upon the exact shape and dimensions of your "u" shaped hinge piece.
  9. Cody Walls
    Cody Walls
    Now to the latch and how to open it , I knew I wanted to make it easy ,accesible, and just the push of a button , mechanical , and hidden so here's what I came up with, since the inside top of the taillight housing is kinda not seen all of the time I'll put the button there.
    So I made a 3/4 round circle 1/8 thick peice and a 3" by 1" 1/8 thick peice straight out of stainless for the start of the button , here I just tacked it to the frame so I could line it up with the hole in the housing . Once everthing was lined up it was time to start making the mech of the latch to work
    Just a simple pivot to make this work
  10. Cody Walls
    Cody Walls
  11. Amazing as usual!
  12. bikersteve
    bikersteve
  13. Cody Walls
    Cody Walls
    So I ended up forming the end over to make one side of the catch .
    [​IMG] and I made a backing plate for the other catch which bolts threw the fiberglass
    Now for the fill tube I just pick up some 2 " u bends and cut and fitted the to make the new fill neck .
    And it's all finished
  14. butch27
    butch27
    That is just too damn cool. Good work!
  15. flypa38
    flypa38
    Man that's cool! Just make sure you insulate the hell outta that tail light wire! Enough slack to open it means possible chafing from vibration, which means short, which means sparks, and if the gas filler neck is there it means fire!
    But like I said......man that's cool........
  16. Crankhole
    Crankhole
    Awesome job. Great tech.
  17. nali
    nali
    Nicely done !!!
  18. George G
    George G
    Holy crap. Most excellent.
  19. Nominal
    Nominal
    That's very clever. Nice work!
  20. Jack60
    Jack60
    from Maryland
    Very nice, I have a 55 Cameo, and thought where I was going to put gas tank and fill... May I use your setup........???
    Once again nice job..........:cool:
  21. junk
    junk
    WOW! that is slick!
  22. slobroy
    slobroy
    I'm stealing that one. Great tech.
  23. slddnmatt
    slddnmatt
    very nice tech, i like it!
  24. NealinCA
    NealinCA
    I dig the "washing wachine" hinge. Great tech!
    Neal
  25. 30roadster
    30roadster
    Great Tech... thanks for sharing!
  26. That's really slick!!
  27. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    Fantastic!
  28. resqd37Zep
    resqd37Zep
    from Nor Cal
    I Love it! Thats too kool man!
  29. cretin
    cretin
    I dig the latch.
  30. heatmiser
    heatmiser
    from mia
    very cool! and you make it look too easy...
