Tech: Cheap Ford Falcon Disc Brakes
Discussion in 'The Hokey Ass Message Board' started by Drive Em, Mar 9, 2011.
  1. falcongeorge
    falcongeorge
    from BC
    Just found this, really good stuff, but as far as I know the scarebird stuff uses the smaller gm calipers and 10" rotors, so it would not have as much braking force as this deal. Nothing wrong with that, the original sixties ford front discs were 10", just something to be aware of, comparing this deal to the scarebird stuff is apples and oranges.
    I cant speak for down in the states, but around here, if you DO see a Granada/Monarch in a wrecking yard, the spindles will be LONG gone. Everybody and thier dog knows about using the granada spindles, including the wreckers, and if you DO find them in a wreckers, they will not be cheap, bump-steer issues or not.
  2. metalshapes
    metalshapes
    Most brake setups meant for the street lock up the fronts earlier than the rears.
    Because amateur drivers don't know what to do when the rears lock up and the car starts swapping ends...
    So unless there is a problem with the brake balance with too much bias to the rear, increasing the front brakes by that much of a margin will only decrease how much the rears are helping to slow the car down.
    Because the limiting factor was already at which point the fronts would lock up...
  3. those brackets can be bought at any oval track speed shop.i used those brackets 25 years on a street car and never had a problem.
  4. falcongeorge
    falcongeorge
    from BC
    Oh, oh, here we go.;) Oversimplification, and I disagree. A larger diameter rotor will reach maximum braking torque quicker(more leverage, and we are talking in hundreths of a second here, which at high speeds, can equal feet), which, for the same reason that stiffer calipers do, will shorten stopping distances at high speeds with a skilled driver who does not lock the brakes.Assuming the same design and material of rotor, larger rotors also dissipate heat faster.Arguably, the leverage issue may be splitting hairs, the heat dissipation issue certainly is not.
    But yes, ultimately, IF you slam on the brakes and lock them up, the contact patch will ultimately govern the braking distance.
  5. 1971BB427
    1971BB427
    from Oregon
    Just finished doing a similar swap on my buddy's street gasser. He's got an Econoline straight axle, and an Explorer 8.8 with disc brakes in the rear. We used Speedway weld on rear caliper brackets, and modified them to bolt on the E100 straight axle. Then we got GM metric calipers, and Aerostar rear rotors. Took a day and a little over $100 to build up the whoe swap, and that was with all new parts from the local chain parts store, and no cores to trade in.
  6. metalshapes
    metalshapes
    I was mostly talking about the difference in piston dia's, because that was what the OP referred to. ( so yeah, I admit to some over simplification... :D)
    ( I could have quoted his post, but its pretty old...)
    All the things you mentioned have an impact ( and a big one, when there is really heavy use & and everything is dialed in right ), but when you don't have a good balance you wont be able to exploit the improvements.
  7. falcongeorge
    falcongeorge
    from BC
    Absolutely, I have no problem agreeing with that. Much the same as screwing engine parts together but not having the skills to tune it.
  8. metalshapes
    metalshapes
    Exactly...
    That's what I meant.
    My wife's '63 ( Granada front discs & regulator, Maverick rear axle & drums, V8, C4) has a lot of front end bias.
    That's why I thought putting more bias on the front might not improve things.
    And for extreme use ( like road racing ) bigger is better.
    No argument there...
    ( never had too much brake on the track, but I cooked a couple...:rolleyes:)
  9. falconsprint63
    falconsprint63
    from Mayberry
  10. NOPSI
    NOPSI
    The resurrection of this thread illustrates the gold that can be mined from just below the surface of the HAMB.
  11. Great post, thanks.
  12. 30modelacoupe
    30modelacoupe
    Very well done tech thread!
  13. colhogen
    colhogen
    from Baltimore
    I'm in the middle of doing this exact setup. Using the recommended 7/8 spacers leaves me with a sizeable gap between the front pad and rotor. Seeing that these calipers dont float like modern ones. Seems like a lot of distance to take up with shims. Longer spacers will cause the dogleg to hit the spindle. Anyone else experience this issue??
  14. Relic Stew
    Relic Stew
    from Wisconsin
    Those calipers float, so the gap will be taken up as the piston extends. The Granada rotors are a little thinner than the GM calipers were designed for. If it's in the mockup stage, you can use a compressed air blowgun into the brake hose hole to check travel. With that much gap, my concern would be the piston pushing past the seals when the brake pads are worn down.
    On a side note, the 1972 Thunderbird rotors have the 4.5" pattern and use the same bearings, but are 11.72" diameter. They are a one year only deal, as the bolt pattern went to 5 on 5" and bigger bearings for '73. They cost about 3x the 11" rotor, but are an option if you want that extra bit of braking. Should just need to cut the caliper mounts a bit longer, and check rim clearance even with 15".
  15. RT Reynolds
    RT Reynolds
  16. RT Reynolds
    RT Reynolds
    I loved the guidance on putting Disks on my 63 falcon, but I need help, after putting 3 master cylinder on it and a aftermarket residual valve since all three didn't have one it them, I still have a spongy pedal, I have used a power bleeder, and bleed manually using 1 gal of brake fluid, I'm lost what to try next please help
  17. RT Reynolds
    RT Reynolds
    NO I had to buy one from Jegs and add inline
  18. goldys.garage
    goldys.garage
    A video (YouTube) demonstrating the install , with the spacers, and tuning would be terrific - if one doesn't already exist.
  19. lc1963
    lc1963
    from iowa
    A buddy of mine used a kit from auto city classics. May not be the same size rotor. $399 kit from 4 lug to 5 lug 60-65 falcon is very reasonable and worked well.
    Sent from my SM-G935R4 using The H.A.M.B. mobile app
  20. JohnnyP.
    JohnnyP.
    Bringing this back up to the top. Great tech article!!
  21. zzford
    zzford
    I just checked Speedway. It says they're 5/16" thick.
  22. Toybreaker
    Toybreaker
    Started this project for my 70 mustang in 2008. Life (military deployments and retirement from the military)got in the way.
    Rotors and calipers are sourced from parts stores, look that up yourself.
    This is all Speedway motors sourced. Accurate as of 230 pm 22 April 2020
    Caliper bracket 91641008 $9.99 X2
    7/16-20-#4 AN "kit" 6172940 $29.99 X1
    3/16 IF to #4 AN 6174029 $9.99 X1
    18" #4 Brake hose 1064026218 $14.99 X2
    Plus sourcing the necessary spacers to get the caliper properly positioned.
    $89.94 plus shipping (get it over $99 for free ground shipping)
    I grabbed some 95 Crown Vic Rotors and 71 chevelle calipers from a local pick a part in 09, Resealed the calipers after disassembly and inspection, turned the rotors and all in I am at $142.36.
    I am a Machinist by trade so the spacers will be easy for me to do. Going to make them out of Ti since I have some on hand and it is light.
