Customs Teardrop taillights
Discussion in 'The Hokey Ass Message Board' started by jeffg1010, Jun 10, 2020.
  1. jeffg1010
    jeffg1010
    I have a project that I am installing teardrop taillights on.
    Does the point go up or down?
  2. Ted Chandler
    Ted Chandler
    I don't know what is "correct", but I like the flow of the point up picture better!
  3. Squablow
    Squablow
    On a '39 Ford, the point was on the bottom. On a custom application, you could do it however you wanted, whatever looks right. No wrong answers.
  4. 38's are the same ;)
    Gangrene likes this.
  5. Bandit Billy
    Bandit Billy
    They wouldn't call them tear drops unless they were shaped like 'em. Point on the top.
  6. It's your car but point goes down.
    Mick
  7. Hnstray
    Hnstray
    from Quincy, IL
    I understand your thinking, but it’s the shape, not the orientation, that suggested the name. They could just as easily, and probably more accurately, be called an elliptical shape or perhaps an oval.
    An actual teardrop has no natural resistance to gravity, but a taillight is fixed in position and can defy gravity. That said, I agree with @Squablow .
    Ray
  8. lostone
    lostone
    from kansas
    Point up to match the flow and line of the fender getting thinner towards the top on body lines.
  9. Almostdone
    Almostdone
    Starting to sound like the peanut butter vs. chocolate add for Peanut Butter Cups.
    I’ve seem them both ways, usually point down.
  10. arkiehotrods
    arkiehotrods
    Ford gave a big clue in '38/'39 as to the orientation of the tail lights. The bezel screw is at the bottom, not the top, meaning the point faces down, not up.
    TagMan, jimgoetz, Gangrene and 11 others like this.
  11. How about sideways
    vor, warhorseracing, Hnstray and 5 others like this.
  12. hotrodjack33
    hotrodjack33
    *Warning* politically incorrect post:eek:
    Or slanted...for certain imports
    vor, Texas Webb, jimgoetz and 2 others like this.
  13. The37Kid
    The37Kid
    Were is the front of a drop tank?:rolleyes: 052bebd1d36e3367d7bacc4b7e47d6a6.jpg
    southerncad, Hnstray and loudbang like this.
  14. 41rodderz
    41rodderz
    from Oregon
    The37Kid likes this.
  15. Fortunateson
    Fortunateson
    Well actually there is a very specific way to mount them and it's based on physics. Now it's your car and you can mount them whichever way pleases you most. If you want to get the best effect the point has to go down, this is simple aerodynamics. You'll get higher speeds, lower fuel consumption, better handling, and a host of other benefits if you follow the "Laws of Physics"!
  16. 3banjos
    3banjos
    from NZ
    Yep, matches the trunk lid handle on that very cool coupe.
    catdad49 and lothiandon1940 like this.
  17. I can't believe this is even a question.
  18. Road Angels
    Road Angels
    Screw down...but what ever floats your boat...have fun with it
  19. brady1929
    brady1929
  20. Unless of course, You live in the southern hemisphere...:rolleyes:
  21. No screw ups here;)
  22. low down A
    low down A
    who's they? the chinese call them teardrops ford men call them 38-39's
    jimgoetz likes this.
  23. hotrodjack33
    hotrodjack33
    Nope, I disagree. The laws of physics tell us that the "drag coefficient" is less with the taillights mounted upside down (point forward/up)...not that anyone gives a "rats ass":p:p:p:p
    Also, that's why boats are pointy in the front:D
    southerncad likes this.
  24. Hnstray
    Hnstray
    from Quincy, IL
    Well, then.....Perhaps you’d like to ‘splain ......Boat Tail.....always a taper, so where did that term originate? And aircraft wings, control surfaces, fairings (bulges) are always a bit more blunt at the leading edge and taper to guide the disrupted air flow to a smooth (not turbulent) confluence. ;)
    Ray
  25. Cheez Whiz, guys. You're getting way over my head with this talk of physics and turbulence and drag coefficient and air density.:D..........Just mount 'em right and be done with it.:D;)... 20151126_0923432_zpsuspeggab.jpg
    Blues4U, lo c dan, TagMan and 11 others like this.
  26. Model A Gomez
    Model A Gomez
    I've used them on several cars and like them better point down but that is a presonal opinion.
    hotrodjack33 likes this.
  27. goldmountain
    goldmountain
  28. 1946caddy
    1946caddy
    from washington
    Where did you come up with this interpretation of how the airflow of a aircraft wing works?
    The wing is round at the front and tapers back to provide lift to the wing. The taller the front of the wing is , the more lift but also more drag.
  29. brigrat
    brigrat
    from Wa.St.
    This hole thread is "pointless"...……………………………….
