I need to buy some tapered bungs for early ford tie rod ends. I think they are 7 or 7.5 degree tapers. I've run out of pieces to cut them out/off and surely somebody sells them..........I hope.
Pretty sure he meant things to cut them off of. Like spindle ends and such. Its a LOT cheaper to buy bar stock than bungs.
It might be cheaper to buy bar stock but unless you buy the reamer, the bar stock doesn't do you any good. The bungs are only $3-4 at Speedway.
I think we need a tutorial on how to use a reamer. crminal, you just blew my mind with that photo. Whats the mount on the frame look like?
True, but he also said, "early ford tie rod ends". (forgive me if that was a Bevis reference) Hillbilly4008, nothing I came up with, to give credit where it is due; www.ctaulbert.com Takes a regular type mount, like a later ball joint, but with an early ball that fits that tie rod end.
Is he looking for the weld bungs to go in the wishbones OR is he looking for the bung that has a 7degree taper to use on tapered tie rod ends? Fuck me I'm lost
He said: "I need to buy some tapered bungs for early Ford tie rod ends. I think they are 7 or 7.5 degree tapers." No mention of wishbone bungs which wouldn't need a specific taper specified anyway, so I'd interpret his statement to mean a bung which accepts the tapered stud on a Ford tie rod end. Bob
the problem i've found with the ones speedway sells is they're not deep enough, especially when using the larger truck tierods.
Expensive. Around $120 for a good one. Speedway has them for around $80 http://www.speedwaymotors.com/Speedway-Tapered-Ball-Joint-Reamer-7-Degree,2918.html
Take the bar stock, drill hole for the bolt/nut size, cherry the bung, take a old tie rod end, hammer/press it into the steel and you have a bug. Dont need a reemer as you just forged it to size. I can have enough made for a car by the time you get off the phone ordering them
turn the compound on a lathe to 7 degrees and bore away? Thats what I've always done and not have a problem.
