Tail light problems
Discussion in 'The Hokey Ass Message Board' started by Russell.K, May 1, 2011.
  1. Russell.K
    Russell.K
    I got a 50 Ford and the tail lights were working fine. Then they just stopped. When I flip the light switch they don't go on. When I hit the brakes they barely glow and when I hit the blinkers they are a little dim. Head lights work fine though. Any advice?
  2. firemancooter
    firemancooter
    Check your grounds.
  3. rustdodger
    rustdodger
    sounds typical of a bad ground to me too
  4. d2_willys
    d2_willys
    from Kansas
    Tail light fuse blown?
  5. rustyzman
    rustyzman
    from midwest
    +1 on a bad ground. Run a temporary one if need be and check again. If they come back to life with a temp ground, you have found your problem.
