Just picked up another Chevy car been sitting for a while was low on ATF filled now but doesn't seem to wants to down shift. While in DRIVE at 30MPH the tach is screaming at 2300 rpms ? <input id="gwProxy" type="hidden"><input jscode="leoInternalChangeDone()" onclick="if(typeof(jsCall)=='function'){jsCall();}else{setTimeout('jsCall()',500);}" id="jsProxy" type="hidden">
yes .... could the modulator be clogled ? <input id="gwProxy" type="hidden"><input jscode="leoInternalChangeDone()" onclick="if(typeof(jsCall)=='function'){jsCall();}else{setTimeout('jsCall()',500);}" id="jsProxy" type="hidden">
"Screaming " at 2300 Rpms ? Overdrive has spoiled you lol. It won't down shift ?? As in 3rd to 2nd Or it won't up shift as 1st to 2nd and 2nd to 3rd.
If it won't up shift (from 1st to 2nd) check your vacuum line. I was having the same problem and my lines appeared to be ok but they where collapsing under vacuum. Got some reenforced vacuum line aka fuel line and replaced it and its shifting like a champ.
