i know you should use a sway bar on a mustang 2 frontend with air bags.what is the best way to mount a sway bar on tubular a-arms?
Using a sway bar will help you abit. But i would not install it. The air from the one side of the car will still want to go over to the other when you are turning. So if you dont want your car to lean when your driving around corners, You've to have four individual air systems. And i guess you are running on two air systems now? One for the front and one for the back? If so, You just have to buy two more airvalves and some airhoses. /Eric.
