Technical surge
Discussion in 'The Hokey Ass Message Board' started by Huckster59, Jun 4, 2023.
  1. Huckster59
    Huckster59
    i have a 327. eddy carb 650 avs runs good , but when cruising about 2500 rpm’s it feels like it’s surging or missing. but runs good when ya nail it. jets?
  2. greybeard360
    greybeard360
    Put a little softer spring under the metering rods. Surging is usually a lean condition.
    vtx1800 likes this.
  3. If you want to richen the mixture earlier, I think you'll actually want to try a stiffer spring. The softer spring will let the metering rod stay down longer at a given manifold vacuum, thus delaying any enrichment. A slightly smaller metering rod might also help your diagnosis of a lean surge at light throttle cruising speeds.
  4. Huckster59
    Huckster59
    has mallory dual point in it also ,with mechanical. eddy high rise open plane with 1 “ spacer. headers 10” air cleaner
  5. Huckster59
    Huckster59
    i thought maybe starving for air
