have a 40 Pontiac with 76 ventura stub , with a big block ,new coils . the front end sits to low ,money always a issue ....... appreciate any feed back,jack thank you ,for feed back so quick , the problem I have is that the front tires rub ,14" rims ..
Larger diameter tires? You might only gain an inch, but every inch counts in hot rodding. My wife says the same thing....
They make a rubber spacer which can be put under the spring, good for an inch. Combine that with a taller tire, might just get you what you need.
yeah put in rubber spacer to start,cheap. i have a 41 olds and had to get taller springs.15inch tires.
