Stupid Chrysler question.....
Discussion in 'The Hokey Ass Message Board' started by gaskell, Dec 20, 2010.
  1. gaskell
    gaskell
    from CO
    OK, boys and girls....
    I have a 62 Chrysler Newport (very much like the 300). I am trying to get the F!*#$ window cranks off and cant figure it out... Anyone have any guidance?
    I have looked for a pin... cant find one. Looked for a snap ring.. does not look like the head comes off to reviel a screw.. Just dont want to break anything as everything is hard to find for this car.
    Thanks in advance.
    -LarryG
  2. its probobally got a spring loaded clip.. ya need a handle remover tool...
  3. BigBlockMopar
    BigBlockMopar
    I've got a NewYorker with power windows so I don't know for sure but there's probably a springloaded clip on the back which somewhat locks the handle onto the square shaft. If it's the same as on the late '50s cars, you need to hold the crank in the 12 o'clock position and then push on the clip from either the left or rightside of the handle.
    There is only a small edge on this clip to push on so it can take a couple of tries to get it loose.
    I believe there are some pics in a topic on the ForwardLook.net forum, but using search on that site sucks major A so you'll have more luck finding it by letting Google do the searching there like this;
    Google Search
    O well, here ya go...
    http://www.forwardlook.net/forums/forums/thread-view.asp?tid=9023&mid=50030
  4. There is a c-clip on the handle, hard to see. My '66 Newport has them, you have to push the trim panel in a little around the handle area. Do yourself a favor and buy the clip tool, if you don't the dang think will fly across the room (I speak from experience). The only other possiblility would be a screw in the middle of the crank, look close and see if there is a cover over the center of the handle.
  5. ndeconte
    ndeconte
    Yea, 62 I'm not sure if it's a screw or the Sping C clip.
    The C clips can be a pain to get off without the clip tool. It can be done, but it takes some trying.
  6. sololobo
    sololobo
    As they said, just get the tool and then it is a piece of pie! ~sololobo~
  7. autobodyed
    autobodyed
    from shelton ct
    my friend used to call those jesus clips, cause after it flew across the shop, you'd be walking around sayin' jesus where did it go??!!
  8. Mr48chev
  9. Squablow
    Squablow
    No, it's not a screw, no, it's not a pin, NO, it's NOT a C-clip. Read through this thread for pics and the process of removing the handle. You have to use a tool to push the square clip over to one side, and then it slides off, the clip remains in the handle.
    http://jalopyjournal.com/forum/showthread.php?t=533323&highlight=clip
    Or, feel free to spend a few frustrating hours looking for a C clip or a screw that isn't there because a bunch of people who didn't know any better told you what to look for.
  10. pcterm2
    pcterm2
    listen to Squablow-he knows what he speaks of
  11. gaskell
    gaskell
    from CO
    All, thanks. Great leads and even a diagram to make the tool I need. Love the HAMB Happy Holidays.
    -LarryG
