Projects Stuck 292 y-block
Discussion in 'The Hokey Ass Message Board' started by rladams65, Nov 8, 2021.
  1. Wanderlust
    Wanderlust
    I wouldn’t worry too much, after some measurements I would except you’ll find that you will need to rebuild it completely anyway. Mine was a running engine and it still required a complete rebuild. They are extremely tough engines, they will still run pretty well even when worn out
    rladams65 likes this.
  2. OahuEli
    OahuEli
    from Hawaii
    Try squirting PB Blaster into the area where the ring gap is. Another idea, (if you are not in a hurry and which I've done before) is put the pistons in cans just a little larger diameter than they are, dome down of course, and pour Marvel Mystery Oil in to just above the pin and let them sit. It will soak in behind the rings and you can get them out without damaging the piston. A gallon of MMO is way cheaper than pistons and who cares about the rings, you should replace them anyway.
  3. Torana68
    Torana68
    from Australia
    sometimes you can tap the ring out from the gap with a small flat screwdriver and small hammer (tapping on the ring end) . Heating and cooling may help. If your boring it out just bin them, spend time on something useful.
  4. Boneyard51
    Boneyard51
    Use the rings that are loose on other pistons and break them into short pieces and tap them with a small hammer starting a t the gap, driving the rings out of their grooves. Also broken rings make the best ring groove cleaner!
    Bones
  5. rladams65
    rladams65
    That is not what I was hoping to hear - but thanks
  6. rladams65
    rladams65
    That is the same advice Wanderlust gave me - which makes me sigh. Thank you
    Boneyard51 likes this.
  7. Boneyard51
    Boneyard51
    Totally depends on what you are going to do with this engine and your expectations. Folks here on the HAMB have a tendency toward perfection and there is nothing wrong with that. But guys that have made a living as a line mechanic can testify that there are other ways. Many times , on the line, a car would come in for an overhaul and the owner was short on cash. He would get a price for a bore job or just rings and bearings and choose the rings only route. I have seen many engines that needed bored but only got rings and ran just fine and did not smoke! How long the engine continued to run good……not sure, but I saw some with 30,000 miles still going fine. There is difference in building a crusing engine and a race engine. Hone the worst cylinders and inspect and measure, then make a decision.
    Bones
    Truck64 and rladams65 like this.
  8. finn
    finn
    If the pitting is towards the outer edge of the piston crowns, it’s likely caused by detonation of oil sucked past the rings.
    Truck64 likes this.
  9. Truck64
    Truck64
    from Ioway
    Yep, back in the day lots of engines got the "Dingleball" overhaul. Without even removing the engine. DeGlaze the cylinders, new piston rings. New bearing inserts in the lower end, and a new timing set & chain. Bob's Yer Uncle.
    With a Y-Block some attention would need to be paid to rocker shaft oiling.
