Technical Stromberg 97 holes drilled in air horn?
Discussion in 'The Hokey Ass Message Board' started by IronFord, Sep 27, 2021.
  1. IronFord
    IronFord
    from NoDak
    Why would someone drill holes in the air horn of these carbs. Six of them have holes drilled in them.
    Thanks 74C0662C-8684-4CF7-A532-E927E3A89ED1.jpeg DF892375-09DC-489B-B203-0631B1E3A46E.jpeg
    VANDENPLAS, Deuces and Stogy like this.
  2. Stogy
    Stogy
    Well one thing for sure they probably all came from the same owner...
    Maybe that's where the special sauce went...that's crazy eh...
    Early pollution control? As in blowby infused for a second round of combustion...
    They all look to be in the same location...
    Maybe a deburr both side and fill with gas resistant filler...it just penetrates the bore and nothing else...does it sit between the choke plate...
    VANDENPLAS likes this.
  3. BJR
    BJR
    To let unfiltered air into the engine.
    IronFord, Deuces and Stogy like this.
  4. v8flat44
    v8flat44
    Just to confuse the next owner......interesting though.
  5. Stogy
    Stogy
    Maybe they were experimental carbs and had analization equipment in them...
    VANDENPLAS and Deuces like this.
  6. Cmon guys.. Its for methanol injection !
    VANDENPLAS, Stogy and Deuces like this.
  7. Deuces
    Deuces
    I've seen a factory
    L-79 Holley carb that had small 1/8 inch diameter holes drilled into the venturi body a half inch above the throttle plate....
    Stogy likes this.
  8. carbking
    carbking
    Both Stromberg and Carter once supplied tech schools with carburetors for the students to use for learning purposes (disassembly, reassembly). Possibly Holley and Rochester also did the same, but I have no proof of that.
    Both Carter and Stromberg drilled holes in the castings thereby making the carburetors non-serviceable.
    These are commonly referred to as "school carburetors".
    Jon.
    Deuces, IronFord, VANDENPLAS and 3 others like this.
  9. carbking
    carbking
    Just read Dueces post.
    Several different O.E. carburetors used the small holes just above the throttle plates as a method of hot idle compensation. The ones with which I am familiar (Stromberg WW) were located in a "dead" vacuum area, so no "dirty" air enters the carburetor.
    During city driving in the summer (or anytime with deathanol fuel), there is pressure in the throttle body, which if not relieved, causes an overrich condition, sometimes to the point of stalling. The small DESIGNED holes alleviate the issue.
    Please do not read this post thinking one can fix all hot idle problems by drilling the holes!
    Jon.
    Deuces, VANDENPLAS, Stogy and 2 others like this.
  10. Rusty O'Toole
    Rusty O'Toole
    Could someone have been experimenting with water injection?
    IronFord and Stogy like this.
  11. alchemy
    alchemy
    Six out of eight cylinders were running rich, so they needed more air.
  12. '51 Norm
    '51 Norm
    from colorado
    He just never got around to drilling holes in the other 2?
    Stogy likes this.
  13. I've got nothing on 'why the holes' but I think the 2 without holes have oxidized slightly different, like they may have a separate past life.
    Stogy likes this.
  14. Stogy likes this.
  15. I’m pretty sure that Carbking already supplied the answer….
    Budget36 and Stogy like this.
  16. 57Fury440
    57Fury440
    I was also thinking maybe water injection.
    Stogy likes this.
  17. Stogy
    Stogy
    Bad Bootleg batch injection...:D...very environmentally friendly and gets one home WAY quicker...
  18. IronFord
    IronFord
    from NoDak
    Thanks for the reply’s everyone. I’m not sure if the carbs were ran on the intake. This intake was a supposedly ran on a “full race” 331 Chrysler Hemi that came from Ca.
