Hot Rods steering wheel
Discussion in 'The Hokey Ass Message Board' started by dirt t, Mar 12, 2013.
  1. dirt t
    dirt t
    1. HAMB Old Farts' Club
    I want to build a steering wheel and need a hoop. Could someone give me a source ? I checked the HAMB o dex. I need a 15" hoop.
    Thanks
    Terry
  2. I would think that most people that make their steering wheels roll their own hoop. HRP
  3. rockfish
    rockfish
    What HRP said otherwise pick up a cracked swap meet wheel for a few bucks and remove the plastic. Forming your own hoop is probably easier. Low buck method is to heat the rod and form around a plywood disc of the diameter you want.
  4. dirt t
    dirt t
    I don't have the ability to roll a hoop. I am looking for some one who can make me a hoop.
  5. Garry Carter
    Garry Carter
    Hit the swap meets. A company called "Superior" marketed inexpensive steering wheels back in the `60's and `70's. They mostly made 11" and 13" wheels, but did produce a few 15" models. That's what I used to cut down my `39 banjo.
  6. Boryca
    Boryca
    from Detroit
    Find a local tubing fabricator. There's plenty around who will roll mild steel tubing. Chrome-Moly is usually harder to come by, but a good company that deals with aircraft will be able to do it.
    Why does everyone forget to check their yellow-pages?
    Mike
  7. Kyle Counsil
    Kyle Counsil
    my buddy works for a valve company and has a lot full of them and I searshed the lot till I found on that I liked and cut the spokes and went from there...
      331.1 KB
  8. 1951Streamliner
    1951Streamliner
    from Reno, NV
    Ring off a bar stool?
  9. dirt t
    dirt t
    Great Idea!!
    Thanks I'll lookfor one.
  10. Have you checked with any local fabrication shops? HRP
  11. dirt t
    dirt t
    In Kingman, AZ This is where ruarl america starts.
    The one shop here would not return my calls.
  12. Kinda like applying for a job,,go there in person. HRP
  13. dreracecar
    dreracecar
    from so-cal
  14. Atwater Mike
    Atwater Mike
    ...Or just find a pallet. They're rollin' off, grab one!
  15. Mr48chev
    Any metal shop that has a slip roller can roll you a hoop. Most slip rollers have one or more grooves on the open end that a piece of steel rod can be put in and rolled.
    Some may not know how but the welding/metal shop teacher that I taught with 24 years ago only used the big surplus slip roller in the welding shop to roll hoops for different things. He taught a lot of guys who ended up as top rate welders but didn't know the equipment he had in the shop very well.
  16. 33sporttruck
    33sporttruck
    Find a Blacksmith or Metal Fab Shop with a ring roller. They can spin one out for you and weld up the ends. This will work if you are going to laminate the steel ring (core) with fiberglass then sand it for finish. Have Fun !!! Jeff
  17. dirt t
    dirt t
    I stoped by the shop discussed what I needed left phone numbers was told they would call. For a business they need to know that all a customer wants to do is give them money!! A customer only can go so far.
