Steering wheel adaptor ?????
Discussion in 'The Hokey Ass Message Board' started by Sprout, Sep 26, 2006.
  1. Sprout
    Sprout
    I have a 56 f-1 box and a three hole wheel. My question is that I need an adaptor for the spline on the column to go to the three holes, but haven't found any. Any sugg. or web sites to look at?
  2. squirrel
  3. A commercial adapter may be the way to go, but you can make one of your own from an old steering wheel.
    I stripped the wheel, arms and plastic off of a 70 - 80's or so era GM steering wheel.
    A little grinding and clean-up gave me a steel hub.
    I made a drill jig from a friends 3-spoke wheel.
    You could also use the 3-spoke wheel proper for a jig.
    There is room to get the three 1/4-20 holes in the GM hub.
    (There are several factory holes you have to work around.)
  4. butch27
    butch27
    I always just got them from Grant. I've got a Corvair turn signal and steering wheel on top of a '55 F-1 shaft.
  5. Sprout
    Sprout
    Thanks guys...
