Technical Steering Column/ Directional Switch ID Help
Discussion in 'Traditional Hot Rods' started by JimMartley, Jun 19, 2020.
  1. JimMartley
    JimMartley
    20200619_190846_resized.jpg 20200619_190621_resized.jpg 20200619_190655_resized.jpg 20200619_190719_resized.jpg 20200619_190813_resized.jpg 20200619_190838_resized.jpg I bought this 32 Ford 3 window and got it on the road today. FUN!!!!! BUT the directional switch has a crack in it and I am not sure what the column was out of. The previous owner said the column was in there when he bought it 5 years ago. I believe it is out of a GM but the "Hazard Flasher" stalk on it does NOT ring any bells in my memory. It is part of the switch and is Red in color with the word FLASHER right on it. Any help would be appreciated....Thanks!
  2. Paul
    Paul
    Editor
    Mid sixties Chevy truck?
    Hnstray likes this.
  3. squirrel
    67-72ish Chevy pickup, most likely.
    Mid 60s looked different...
    Jibs, Hnstray and Paul like this.
  4. 32fenderless
    32fenderless
    I believe that is early to mid 70’s gm van column.
    harpo1313, Hnstray and ted kovacs like this.
  5. squirrel
    Could be van, the vans and trucks were very similar.
  6. Paul
    Paul
    Editor
    Did I say mid?
    I meant late ;)
    I'm using the floor shift version in my T
    squirrel and Hnstray like this.
  7. The vans had shorter shift handles. Looked better using a smaller wheel. The turn signal usually failed because of broken return springs in the switch. You can just change the springs and your good. Some reason one spring was red the other green.
  8. JimMartley
    JimMartley
    Hey, just wanted to say THANKS to all that responded. It turns out the column WAS from a 67-72 Chevy truck/van and I did find a repo directional switch with the "correct" red push/pull button that has "FLASHER" written on it....
    Paul likes this.
