Steadfast, 1931, Ford, Model A, Coupe, Hot Rod, Street Rod, 5 Window, 1932, 1930, 1929, 1928,
Discussion in 'Cars For Sale' started by Steadfast mfg, Dec 31, 2018.
  1. Steadfast mfg
    Steadfast mfg
    City: Mansfield
    State: Ohio
    Price: 37,500.00
    SOLD!!!!
    But we could hook you up with something similar :cool:
    Everyone knows that the Model A Coupe on deuce rails is the coolest Hot Rod to build right now.
    Here is your chance to own a Hot Rod that will demand attention when you roll into any Rod Run or Goodguys show!
    I personally don't want to waste my time building a Hot Rod that wont get attention and neither should you! I want something to sit right, looks right and demands everyone's attention! [​IMG]
    Since not everyone can get that perfect stance and use the right combo of parts, I am making it easy by setting it up for you!
    YOU can make this Steadfast Hot Rod all YOURS by setting it up with YOUR COLOR of choice, YOUR Motor & Trans combo and YOUR INTERIOR color & style!
    One thing you will notice is how low it sits. This Hot Rod is 100% drive-able at this ride height.
    Johnsons Hot Rod Shop rear sway bar that helps eliminate body roll. This way you don't have to worry about the tires rubbing the body around an 80 mph entrance/exit ramp!
    If you have any questions regarding this Hot Rod feel free to contact Henry at Steadfast Mfg and ask away!
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    Here's a list of what you get....
    Steadfast
    Perimeter ~ Chassis for a High boy/flat front/Model A pinched rear 3,200.00
    • 5in. Dropped I Beam 400.00
    • Durant Super Low Front Spring 220.00
    • Spindles 225.00
    • Front Shocks 75.00
    • U-bolt Eliminator 50.00
    • Adjustable Perches 140.00
    • So Cal SS Front Shackles 90.00
    • King Pin Set 50.00
    • Tie Rod Kit 77.00
    • Drag Link Kit 81.00
    • Vega Box 350.00
    • So Cal Pitman Arms 70.00
    • Steering Arms 95.00
    • Vega Box Mount 50.00
    • Lower Shock Mounts 70.00
    • Spin Nuts 15.00
    • Front Brakes Johnson Kinmonts 2,800.00
    • Quick Change Rear 3,250.00
    • " shipping 150.00
    • P & J Ladder Bars 450.00
    • Set up for Johnsons Rear Sway Bar 250.00
    • Rear Pan Hard 132.00
    • Lower Shock Mounts & Brackets 185.00
    • Rear Spring 400.00
    • Rear Spring Hangers 100.00
    • Rear Shackles 90.00
    • Rear Shocks 75.00
    Wheels & Tires
    • Fronts: 16 x 4.5 / 500.16 Dirt Trackers
    • Rears: 18 x 7 / 700.18 Tires
    • Wheels Painted Black, Tires & Tubes $2,800.00
    Miscellaneous
    • Walker Radiator
    • Brookville '32 Radiator Shell
    • Steadfast Custom Seat Frame ~ New
    • '32 Car Dash
    • So~Cal Gauge Insert
    • and miscellaneous extras
    Body
    • '31 Steel Five Window Coupe
    • Steadfast Floors
    • '32 Style Firewall installed
    • 4 1/4 inch Chop
    • Brookville Deck-lid
    • Brookville Cowl Vent installed
    • New Wood Kit
    Engine & Transmission NOT INCLUDED at this price!
    Note: Parts are Pete & Jakes unless noted otherwise.
    This is a "Roller Project" unfinished, not currently running Hot Rod ... contact Henry !
    Located in the middle of Ohio, USA!
    Delivery available, message us with your zip code for delivery fee quote.
    Item being offered locally auction can end at any time!
    Steadfast Manufacturing specializes in custom hot rod fabrication and product design. We manufacture and sell our own products that are designed and built in our own facility. None of our products are manufactured outside the USA.
    Additionally, we are authorized sellers of high-quality hot rod and performance parts from Pete and Jake*s, Perfection Hot Rod Parts by Johnson's Hot Rod Shop, Brookville Roadster, John*s Industries 9 Inch Factory, Vintage Air and LimeWorks, just to name a few.
    Follow us on Facebook or Instagram: at steadfastmfg
    ratamahata, Stu and Darryl Deir like this.
  2. Steadfast mfg
    Steadfast mfg
