Technical Spotlight switch source
Discussion in 'The Hokey Ass Message Board' started by RodStRace, Mar 7, 2022.
  1. RodStRace
    RodStRace
    A good friend has a problem with the switch. No brand or name was seen.
    Where can he find a replacement.
    Boneyard51 likes this.
  2. deathrowdave
    deathrowdave
    from NKy
    I have one of the more modern style switch’s laying around if you would like to have it .
    wraymen and RodStRace like this.
  3. RodStRace
    RodStRace
    thanks for the offer!
    He would probably prefer a direct swap, but I will pass this along, if he's not watching.
  4. You might be able to pull the switch apart and clean it.
    302GMC, RodStRace and dirt t like this.
  5. RodStRace
    RodStRace
    Thanks, yes it may be able to be repaired, but would rather have a replacement switch because
    1. these are probably getting harder to find each year, might as well have one spare, and
    2. the chances it can be serviced increase when you have a replacement on the seat. Just like the flat tire happens a lot more when you don't have a spare!
    Really hoping someone can ID the light/switch and offer a part # or source.
    My friend is a great caretaker of this beauty, but isn't ready to dive into disassembling this in his narrow 1-car storage garage. I'd love to swap it out, but will be going back home hundreds of miles away shortly and don't want to leave it apart or slapped together still not working. Looking at it, I know there is at least one spring in there, and I don't want to break or lose parts. If it was mine and at home, I'd take the risk. I'm hoping that I can get the part and fix it for him, right, the first time for sure.
  6. deathrowdave
    deathrowdave
    from NKy
    That is a GM S16 accessory spotlight . There is currently a complete handle on EBay for sale . It’s rather pricy , but it’s available if you choose to purchase it .
    RodStRace likes this.
  7. RodStRace likes this.
  8. RodStRace
    RodStRace
    Thanks, gentlemen!
    Currently in LA, so if one is available, it's a decent bet it can be found here. I'll be able to check the local places now I know what to ask for. GM S16 will narrow it down well.
    The HAMB comes through again!
    I asked the owner this morning to look for this thread. He can make the call on repairs and parts.
  9. RodStRace
    RodStRace
    We went ahead and dove in, got it fixed!
    The bulb is out, so will have to get into the other end.
    Again, thanks for the information and encouragement!
    lothiandon1940 and pprather like this.
  10. RodStRace
    RodStRace
    got the bulb end all figured out, but couldn't source a bulb today.
    my friend has a firm grasp of the procedure to replace and will swap once he finds a bulb.
  11. RodStRace
    RodStRace
    many thanks! GM part L4535 , 6 Volt, part number 444279
    his is not a sealed beam, rather a riveted bulb and reflector.
    the glass is separate with a rubber seal and the single wire is soldered to the slip ring at the pivot.
    the ground is provided through the reflector to the body of the light.
    like this one,that has a bulb number I'll follow up on.
    https://www.ebay.com/itm/363741822557
    "The bulb has the number 1323 on it and it says 32C 6-8V so it is a 6 volt bulb "
    the one you found may work as a replacement, but would require a bit of fitting.
    I'll pass this along and hope he can use it. only concern is the locating lug all sealed beams have and this one seems to have too, along with the wiring.
    this has been a bit of an effort because I'm away from my usual desktop , the laptop is lame and I'm not used to doing all this on the phone. learning while on a trip is going to happen, it's growth, right??
    pprather and lothiandon1940 like this.
  12. I will leave the seal beam info above for future reference if someone has the newer version of the N 23 light with seal beam bulb.
    For the 1323 bulb, is the base on this one look correct?
    https://www.interlightus.com/light-bulb/1323
    Looks like 1209 may be a newer number, for this application.
    https://replacementlightbulbs.com/lamp1323.html
    Here is a reasonable cost source with several cross reference numbers:
    http://www.classicautobulbs.com/automotive-light-bulbs/antique-vintage/1323-p15s30-25w-clear-6v.htm
    That should be enough info to keep this project moving.
    Hope this helps.
