Original 28-31 Model A Ford Wishbones that have been split for an AV8 or traditional hot rod project. Wishbone was sandblasted then split with bungs TIG welded in with new speedway early ford tie rod ends. The wishbones were epoxy primed and painted semi-flat black. The overall condition is pretty good with some light pitting that could be filled with high build primer. One of the wishbones has a dent in it about 6" back from the perch center but It could be filled if needed. These measure approx. 36" from perch center to tire rod center and have a 2 1/4" perch boss. Please PM with any questions or call Jim 865-531-1840. $175.00 shipped in lower 48 states. SOLD, Thank you
