Hot Rods Spindles
Discussion in 'The Hokey Ass Message Board' started by butch27, Jun 30, 2020.
  1. butch27
    butch27
    What is best---cast iron....cast steel .. forged ??
  2. alchemy
    alchemy
  3. Of the choices shown, I say you listed them in reverse order of what I would use.
  4. Mr48chev
    Forged rather than cast on any suspension or steering part.
    butch27 and Just Gary like this.
  5. birdman1
    birdman1
    okay, explain the difference between cast iron(really??) and cast steel( i think China made that up)??
  6. Hnstray
    Hnstray
    from Quincy, IL
    Both iron and steel are molten in some part of their processing, but not the same metallurgy.
    Ray
    alanp561 and butch27 like this.
  7. butch27
    butch27
    TRUE
  8. alanp561
    alanp561
    Break a piece of cast iron and look at how grainy it is. Break a piece of carbon steel try to find a grain in it. Cast iron is called a "grey" metal and generally has at least 2%carbon while cast steel has 0.10.5% carbon.
  9. Mr48chev
    A forged axle or spindle will bend in an impact. A cast axle or spindle will usually break. Somewhere in my photo archives from the mid 70's there are some photos of my 48 after a wreck with the axle bent back at a 90 degree angle. The wheel bent, the spring was a mess but nothing broke. if the axle had been cast it would have snapped in two. I could probably have taken that axle to Waco Spring and had it straightened but my buddy found me another axle and springs for a friendly price.
  10. 2OLD2FAST
    2OLD2FAST
    from illinois
    Forged is cast steel billet pressed/ stamped in to shape , realigning the grain in the steel .
  11. krylon32
    krylon32
    from Nebraska
    1. Central Nebraska H.A.M.B.
    Nothing beats an original pair of 37-40 Ford spindles, coming in second if they're worth the effort to you are 35/36 spindles which will give you an additional 1/2 inch drop over the later spindles and finally if your using side steering the 32/34 spindles also give the 1/2 inch drop and have a forged upper steering arm. I've used all of the above on various customer chassis builds. I personally like to use MT Lincoln brakes on the front of the chassis I build both for the early looks and the ability to stop the car and they are a bolt on with some minor machining.
    gimpyshotrods likes this.
