Technical Speedometer troubles
Discussion in 'The Hokey Ass Message Board' started by Rocket88, Apr 28, 2014.
  1. Rocket88
    Rocket88
    I got the speedo working in the Olds.
    At first it made quite a bit of noise, so I undid the cable and managed to shoot some silicon spray in the speedo head, now it is quiet.
    When I'm driving down the road the needle fluctuates up and down by about 20 mph.
    It eventually settles down and seems to read fairly accurately, but then it will jump around out of the blue then settle down again.
    Any ideas?
  2. did you lube the speedometer cable too?
  3. DrJ
    DrJ
    Go to an OLD parts store and get a tube of actual speedo cable lube.
    (It will be the place n town that still has a machine shop in back.)
    Pull cable out of the housing from the speedometer end being carful not to get that crud all over the upholstery and wipe off and relube and reinstall
  4. Inked Monkey
    Inked Monkey
    Did you lube the cable really good?
  5. Inked Monkey
    Inked Monkey
    You guys are faster at responding than me.
  6. yep , three responses all at 10:10 saying lube the cable
  7. ol-nobull
    ol-nobull
    Hi. Just be sure that you understand that the cablelube is NOT A LIQUID LUBE, it is powdered graphite.
    Jimmie
  8. Rocket88
    Rocket88
    Well, once again I've overlooked the obvious! (insert dumb shit smiley here)
    I'll pick up some proper lube and see how it goes.
    Thanks for the replies fella's.
  9. As an alternative if you can't find the graphite, go to a motorcycle shop and get a spray can of cable lube. Designed for clutch/throttle cables, but works well on speedo cables too.
  10. ROADSTER1927
    ROADSTER1927
    Lithium grease will work real good also, that is what I use in my shop.
  11. TwoLaneBlacktop
    TwoLaneBlacktop
    from Burien
    If it's one of the old cable assemblies with the steel outer housing. Take the whole assembly out, coil it up, and put it in some oil overnight. The old assemblies didn't have a teflon liner in them......Or you can do as the other guys have said and keep trying to get the graphite down inside the outer housing......
  12. dirtracer06
    dirtracer06
    When your done greaseing up the cable, pull the little gear out of the trans and see how bad its chewed up...my 71 did the same thing until i replaced the plastic gear....
  13. Rocket88
    Rocket88
    Gears in the tranny are new, it was part of speedo project to begin with.
  14. oldsjoe
    oldsjoe
    I'll take the Olds speedo working or not! Just puttin that out there! Ha Ha
  15. e1956v
    e1956v
    Alliance Vendor
    Do not use graphite, use lithium grease. It sounds like a bad jewel in the magnet if greasing the cable doesn't work I think the speedometer will need to be repaired.
  16. Rocket88
    Rocket88
    Cleaned and lubed the cable last night.
    Drove to work today, way better.
    It still has a slight fluctuation, I guess I would too at 65 years old.
    Thanks guys.
