Projects Southeast Gassers 65 Comet Super Stock Wagon
Discussion in 'Traditional Hot Rods' started by southcross2631, Oct 28, 2020.
  1. oldiron 440
    oldiron 440
    What would be different with a FE other than less money in the bank. There's others winning with the sbf.
  2. saltflats
    saltflats
    from Missouri
    Weight break.
  3. oldiron 440
    oldiron 440
    It's not hard to screw together a 500hp 347, try hard and make 575. Hell my 292 w made 455 on the dyno only turning it to 6300.
  4. saltflats
    saltflats
    from Missouri
    Dyno and the track are two different things ;)
  5. Horsepower is great, but the class is limited to a 7” tire…….
    Blues4U, Joe Travers and loudbang like this.
  6. 6sally6
    6sally6
    Welp.......it may not BE HARD to screw together a 500 HP 347 but it IS expensive to get one to last with heavy abuse of weekend racing!!
    Especially a stock FoMoCo block.
    Any power much above 500HP will have cracks come in it at all-the-worng-times... and the smoke tends to get out.
    (or so I've "heard"!!)
    Throw enough $$ at it and reliability comes back.
    Maybe de-stroke a 351 Clevor engine and wind it to the moon
    Jus money!
    6sally6
    Thor1 likes this.
  7. oldiron 440
    oldiron 440
    A 363 Dart short block are only 5500. And don't kid yourself about the dyno, the winning guys are flogging combinations on the dyno.
    chevyfordman and loudbang like this.
  8. southcross2631
    southcross2631
    You guys are good at spending a retiree's money. :rolleyes: My ultimate choices are to figure out what I have .
    Build a Good $ FE . Build a big 347 which would be my cheapest way to go because I could use everything I have and just buy a block and pistons. Since they use a 3.25 stroke and 5.4 rods.
    Clevor's are not legal . You must use a 20 degree inline head.
    Let me screw this thing back together and see how it does with the new cam. Then if the money gets right a Blue Thunder dual quad intake and 2 660 Holleys.
  9. 1934coupe
    1934coupe
    Southcross I don't know if you mentioned it, and I just went through the SEGA rules for S/S but are you racing heads up or is it dial in for each S/S car?
    Pat
    Thor1 and loudbang like this.
  10. Joe Travers
    Joe Travers
    from Louisiana
    That's the way to go on a budget. I think the dual quad setup (and maybe the Howard cam) would be the ticket. I don't know about the 347 stroker for longevity. The 331 may serve you better in the long run. The rod/stroke ratio is a bit stressful on the 347. Things could go South rather quickly in a high rpm drag build. JMO.
    Joe
  11. southcross2631
    southcross2631
    It's heads up pro tree 1st to the finish line no buybacks. You run 2 rounds of qualifying one round in each lane and then the fastest runs the slowest and so on. The faster car gets lane choice.
    I can buy a big bore Dart block just under 2 grand and a set of lightweight forged dome pistons for around $600 and build a big bore 347 with a short stroke so the rod ratio is not as bad as a small bore 347.
    Saving up for the intake first because it will work on either motor.
  12. 1934coupe
    1934coupe
    SC it's never ending.
    Pat
    loudbang and saltflats like this.
  13. saltflats
    saltflats
    from Missouri
    Play with what you have and wish for more.
    Gammz, loudbang, Thor1 and 1 other person like this.
  14. oldiron 440
    oldiron 440
    I haven't heard that argument in fifteen or twenty years, that and the oil rings going past the pin being a problem. With all the 347s built including the turbo 1000 + hp builds I don't think it is a concern, the 363 is the same rod and stroke, the best thing for the sbf is an aftermarket block.
  15. Joe Travers
    Joe Travers
    from Louisiana
    How far can you bore the Dart, .060+? I've run .060 over 289 blocks without a problem years ago.
    Joe
  16. oldiron 440
    oldiron 440
    4.125 is what you can order but I'm not sure how far they can be taken...
    4.185 is the biggest bore...thats 374 cid.
  17. Joe Travers
    Joe Travers
    from Louisiana
    Thanks, Grumpy! I'm behind the times, obviously.
    That would make a deep-breathing, high-revving mill for sure with whopper heads and big cam :)
    Joe
  18. 1934coupe
    1934coupe
    More $$$$$$$$$$$$$$$
    Pat
    loudbang and TA DAD like this.
  19. oldiron 440
    oldiron 440
    Check out the main caps and the specs.....
    https://dartheads.com/sbf-iron-eagle-blocks/
    Where's the beef! Lol
  20. loudbang
    From that Dart link
  21. southcross2631
    southcross2631
    Got my parts from Jegs this morning. Good service from Jegs and FedEx to order on Friday and be delivered on Sunday. UPS doesn't deliver on Sunday which will make me consider do I buy from Jegs and get my stuff on the weekend or Summit and wait 2 extra days to get my parts.
  22. oldiron 440
    oldiron 440
    Faster horses, younger women and more money! Lol
    brEad and loudbang like this.
  23. lippy
    lippy
    from Ks
    A 408 W injected on 25% nitro seemed to work ok. 8500 with Scat rods and crank.;)
  24. oldiron 440
    oldiron 440
    There is a guy on YouTube that split a 351 block in half with a blower, he has a 63 Fairlane gasser.
  25. 6sally6
    6sally6
    Here's a 351W(base) powered SEGA car. A good bet it AIN'T a FoMoCo block but......it ain't an FE motor either!
    Love to watch this kid 'Cut-It-Loose' when he runs. WOW!
    9000+RPM shift points and he don't baby-it!!
    6sally6
    sidevalve8ba and Thor1 like this.
  26. rlsteel
    rlsteel
    there's also a guy on u tube( Project stock bottom end) that has ran deep into the 9 seconds with a turbo 302 fox body and a stick shift. Motor has held up for a ton of passes.
  27. lippy
    lippy
    from Ks
    Lots of guys have split lots of blocks of every different brand in half with blowers.:D I have dissected a couple. lol. I have trashed them without a blower so bad that you couldn't tell what it was. lol
    Thor1, loudbang and rlsteel like this.
  28. southcross2631
    southcross2631
    I am not worried about damaging a block unless I put a rod through it and then I have another 289 block. Thinking about going .060 over and building a little screamer. I have a fresh 289 crank that's .020 under. Just need some rods and pistons. Found some Scat 5.155 rods and looking a the pin height for some hollow dome pistons. Some Chevy pistons have the right pin height and valve relief.
    Thor1 likes this.
  29. oldiron 440
    oldiron 440
    I would have a set of custom pistons made and give them a goal of 360 grams that uses a metric ring pack.
  30. southcross2631
    southcross2631
    Yeah, we are looking at that also. I got the motor back in the car yesterday.
    Hope to have it running today or tomorrow at the latest.
    Waiting for the parts store to open so I can get oil and filter.
