SOLD....SOLD......Rochester Tri-power.....FREE shipping to continental U.S. 3- Rochester 2G's remanufactured and configured to run as a tri-power. Carbs are Ethanol fuel ready. 3 Deuce setup for Small Block Chevy. Center Carb modified with New Electric Choke Idle tubes enlarged to .032 Power Piston Modified for Tri-power Mixture screw orifice enlarged to .050 New extended brass throttle rod with screws and primary throttle plates Jetted at .060 for 350 to 400 SBC modified engines New fuel filter Cleaned and remanufactured with new Walker carb rebuild kit Center carb has your choice of manifold or ported vacuum 2 end carbs are modified to function as secondary's with No choke plates No idle circuits No power circuit No mixture screws No vacuum inlets New brass throttle rod and screws with thicker (.080) throttle plates New driver and passenger side linkage hardware New extra heavy torsion spring to ensure throttle plates close Jetted at .060 for 350 to 400 SBC modified engines New fuel filters Cleaned and remanufactured with new Walker carb rebuild kits Carb to intake manifold gaskets are included. Set up for progressive linkage. It is recommend DAG213 be used as a sealer for the throttle plates. Questions? Send a message.
