This is a clean 73 Ford F100 heavy duty housing with big bearing ends that has been professionally shortened for the Bronco 28 spline axles from the same year.Lug pattern is 5X5.5 A transverse spring behind setup has been tacked in place and has new brackets , shackles and a 40 Ford front spring mounted. 3rd member has 2.75 gears and turns smoothly.Drums look ok but will need to be cleaned up.Backing plates and brakes are complete .I'm looking for $275 for everything. Local pickup in Wakefield Mass 01880 only please. Thanks!
