Projects Snake Bit, '30 coupe
Discussion in 'Traditional Hot Rods' started by sloppy jalopies, Dec 17, 2016.
  1. sloppy jalopies
    sloppy jalopies
    That '35 is a landmark... I put it there so you only see it for a second when you drive by...
    when I was a kid there was an oldie behind every barn...
    $400 a ton scrap metal sucked them up...
    so I PLANTED the '35 there... even planted a 3' tall maple tree behind the cab....
    .liked it, so I PLANTED some scraps that resemble a dead cabriolet...
    catdad49, ABONES and Tuck like this.
  2. DDDenny
    HMAB:confused:
  3. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    Yeah I miss that... old cars behind every barn. $500 pickup trucks and the like. Growing up when we were in high school you could always find a truck to drive if you couldn't afford a car.
    Jet96 likes this.
  4. sloppy jalopies
    sloppy jalopies
  5. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    Love it man! This has to be exciting-
  6. WB69
    WB69
    from Kansas
    LOL! That's almost cruel. Bet a lot of people take a double look when passing by.
  7. sloppy jalopies
    sloppy jalopies
    I wouldn't say cruel ...
    I live a quarter the way up the last road going out of town, turns to "washboard dirt" about halfway out...
    29 households, not a ton of traffic....
    In the last 35 years I have had a "shipload" of rusted out '28-'34 ford bodies [247] the locals don't even bother to look in the back yard when they pass anymore ...
  8. sloppy jalopies
    sloppy jalopies
    No sticker but a quick ride on the main road... goes good...
    the C4 chirps 2nd gear rubber...
    inspection station stop Monday... yeh baby...
    only took 1 year longer than it should have !
    Bad back was reminding me of its presence, so I swapped from my '33 coupe body to a '30 A coupe...
    bought me 11" of headroom...
    august of 2017...
    june 2019...
  9. alanp561
    alanp561
    ^^^^^ It just looks right. Well done, well done
  10. wheeldog57
    wheeldog57
    Nice Smitty, good luck on the sticker!
    See you soon
  11. sloppy jalopies
    sloppy jalopies
  12. sloppy jalopies
    sloppy jalopies
  13. sloppy jalopies
    sloppy jalopies
    DSCN4381.JPG DSCN4377.JPG just bolted the narrowed and lengthened 4.5" chebby truck hood top on ...
    catdad49, wheeldog57 and Vic Walter like this.
  14. Vic Walter
    Vic Walter
    I like the half hood !!
  15. sloppy jalopies
    sloppy jalopies
    DSCN4580.JPG DSCN4581.JPG DSCN4584.JPG Trimmed the hood side for ALT. clearance, mounted the sides then top... bobbed rear fenders next... DSCN4585.JPG
  16. catdad49
    catdad49
    Enjoy, Smitty!
  17. -Brent-
    -Brent-
    I LOVE how much the rear horns poke out the back, did you have to shorten those or fab something? It sits really well.
    Edit: I went back and saw what you did. Neat work.
  18. Rodsports
    Rodsports
    G'day Mate,
    Would you have a photo of your front fender set up we could use as a reference please?
  19. sloppy jalopies
    sloppy jalopies
    home made frame,
    made it 20 years ago ,
    pair of model A front frame horns flipped upside down and welded to the kick down so they curl up to almost level...
    Dr.'s office stainless equipment adjustment tube as the spreader bar...
  20. sloppy jalopies
    sloppy jalopies
    hey rodsports …. er... front what ?
    built 10 hot rods so far... '28 to '34 Fords ... never had a front fender on any of them...
    State of Maine, USA. doesn't require fenders, bumpers, also no hood/hood top if you run an electric fan, for you to get a sticker on a hotrod...
    we have it good ! … lucky us...
  21. Rodsports
    Rodsports
    In your earlier post you mention front cycle fenders mounted to the frame. Your rod looks kool man.
  22. sloppy jalopies
    sloppy jalopies
    oh, cycle fenders...
    i like '35 ,'36 ford car spare covers or '49 ,'51 ford woody covers [wider]...
    I use the leading 15" of model A rear wishbones,
    cut out and bolt a 1/4" thick teardrop shaped flange to the side of the frame rail,
    trim and weld the big end of the wishbone to it,
    the wishbone's small end will give you something strong to weld the small piece to...
    cut off a 6" section of the spare tire cover to be used,
    trim along each side so it doesn't show too much when the fender is welded to it.
    weld the small cover section to the wishbone at the correct angles,
    make it strong, then weld the fender to it...
    I mount them sort of vertical and far enough behind the wheel so it does not touch when steering through a bump...
    I have had spindle mounted fenders vibrate themselves to death...
    I won't use cycle fenders for the coupe, but I have a '30 Sportster in the oven...
    if you want to make rear cycle fenders by welding cover strips to each side of your cycle fender, then find different diameter spare covers as they must become smaller as you make the fender wider...
    last set I made was pre computer, sorry no pix.
    I have cut [2] 15" long '35, '36 covers about 1" beyond the beadwork, welded the wide sections together, makes them 2" wider and now with [2] beads...
    any pix Johnathan ?
    catdad49 likes this.
  23. Rodsports
    Rodsports
    Thanks for this information Mate, really appreciated.
  24. coupe33
    coupe33
    Good looking coupe. Living here with a Street Rod plate does make life easier.
  25. sloppy jalopies
    sloppy jalopies
    Makes being a Mainiac cool !
    added bobbed rear mud guards.
    they had been torn and gas welded years ago, I left them, didn't get much bodywork done on the mud guards... DSCN4587.JPG DSCN4589.JPG
    Vic Walter likes this.
