Hot Rods small block chevy identification
Discussion in 'The Hokey Ass Message Board' started by mike howell, Jun 7, 2020.
  1. mike howell
    mike howell
    on the pad at the right front of a chevy small block there is a number m06019vp. can anybody on the forum identify this block. ie c.i.,comp.ratio,yr. etc. ? thanks
  2. Post pic of numbers... They don't compute...
  3. Also casting numbers from back
  4. Could possibly be UP. That would make it a 307, 200hp 2bbl stick engine from a K20
  5. squirrel
    M means Mexico, doesn't it? Replacement crate engine....looks like the VP is the low perf "universal" replacement engine. You can look for more clues, like a pan with a dipstick bulge on both sides, "hecho en mexico" cast on the top rear of the block, etc.
  6. saltracer219
    saltracer219
    Yup, sounds like an old Target Engine.
  7. squirrel
    More likely a later Goodwrench...I thought all the Targetmasters wore out by now?
  8. mike in tucson
    mike in tucson
    from Tucson
    VP does exist, listed as a truck 1969 215hp 350ci L-65 with manual trans 2bbl 3/4t P series low compression motor
  9. squirrel
    Yes, but that one would say T or F at the beginning, not M.
    Although it could be what the replacement engine, is supposed to replace.
  10. mike in tucson
    mike in tucson
    from Tucson
    Agree but I'm not familiar enough with P vans to know if they had
    Mexican motors or not.... P code was also used for motorhomes/RV
    stuff I think.
  11. squirrel
    now you got me interested...so I looked in my 1969 Chevy truck parts book. There is no VP code listed anywhere. Lots of two letter codes that start with U W X Y, but no V.
    Desoto291Hemi likes this.
  12. mike howell
    mike howell
    I'll try to get more info and picks on this block and post it in a couple of days. I appreciate you guys taking time to help me with this puzzle, chevy engines can be difficult !
  13. mike howell
    mike howell
    The casting on the back of the block is 10066036
  14. mike howell
    mike howell
    it is GM Mexico
  15. BigDogSS
    BigDogSS
    from SoCal
  16. mike howell
    mike howell
    Thanks for the info, BigDog and i thank all you folks for for the help!
  17. I just yanked the engine from my box van being used for storage..
    Presumed it had original engine. But NO got a replacement same engine suffix as the OP..
    It is a Mexico engine dual dip stick holes,
    States goodwrench on valve cover so is it a target or a GM engine..
  18. 31 5w
    31 5w
    If you got a good one they are fine, put 1 in a '34 ZZ Top car I built, had 1 in a 30 Roadster I bought. Was 14 yrs. old when I sold the car, dial in a bunch of timing, run Premium fuel . In a 2800 lb car ran scary fast.
  19. 56sedandelivery
    56sedandelivery
    It's a 4 bolt block that came with a cast crank, low compression pistons, and 76 cc chamber heads.
    I am Butch/56sedandelivery.
    Truckdoctor Andy likes this.
