Small block Chevrolet head thickness question ???
Discussion in 'The Hokey Ass Message Board' started by bluecar, Nov 5, 2011.
  1. bluecar
    bluecar
    Hey,
    Is there an easy way to tell how much has been surfaced/milled off of a SBC cylinder head ??
    A place on the head to measure ??
    The orignial thickness from the factory ??
    Just wanting to find a way to see if used heads have enough meat
    on them for a project engine.
    Thanks in advance,
    BC
  2. mgtstumpy
    mgtstumpy
    Check the casting number to establish what they are originally from and you'll then know what the OEM chamber volumes were. Provided the heads haven't been worked, just CC the chambers.
  3. bluecar
    bluecar
    mgtstumpy,
    Thanks for the idea.
    I was hoping that there was a way to measure what I have
    heard called the "thumbprint" to see how much material was left.
    That way when I am out or at a swap meet a quick measure
    with the caliper can tell me if the set of heads are still
    serviceable.
    Best,
    BC
  4. tommyd
    tommyd
    from South Indy
    I think you use the calipers on a head bolt boss to the milled surface. Sorry, I don't know the spec but somebody's gotta know on here.
  5. afaulk
    afaulk
    Better do what stumpy said and measure the "thumbprint" with a burette. Its a good thing to know your compression ratio xxxactly, then you KNOW where to go from there with cam selection and fuel requirements + it just feels good to know ---
  6. 1971BB427
    1971BB427
    from Oregon
    I doubt you could do a reading at a swap meet accurately. Easy to do once you've got them home, but then it's too late.
