Technical Show Us Your Fabricated Parts
Discussion in 'The Hokey Ass Message Board' started by Speed Gems, Mar 29, 2018.
  1. Fabricating parts might be a novel concept to some, but it's what real hot rodding is all about. To me anyway......
  2. DDDenny
    Let's see how long it stays posted this time.
  3. Ken Smith
    Ken Smith
    Alliance Vendor
  4. Hey Denny,
    What's really interesting is seeing the different approach that a guy takes who's strong leg is in machining vs a guy who's strong leg is in welding. Same problems, Different solutions
    loudbang, Hackerbilt and HemiDeuce like this.
  5. Man that's slick , that's all hand ground shape?
    I went to the sign shop today. The had a display up advertising their wears and photos of projects. I was looking at the mechanisms of the display rack and all I could see was carb linkage pieces.
    clem and loudbang like this.
  6. bobbytnm
    bobbytnm
    Good job everybody!!
    I've posted this before but here it is again. I fabbed up this trans adapter to bolt a T5 behind my straight 8 Packard.
    I have to build my own parts....I'm broke 20170319_162125.jpg 20170319_175255.jpg
  7. Paul
    Paul
    Editor
    1/2" brass flat plate, table saw, chop saw, drill press, tap, grind, file and polish.
  8. DDDenny
    Roger that, but you can still see good enough to do both.
    (Sounds like) the perfect recipe for two guys that like each other starting a business together, no thanks, perfect recipes don't always turn out perfect.
    31Vicky with a hemi likes this.
  9. Johnny99
    Johnny99
  10. Paul
    Paul
    Editor
    '27 T turtle deck inner structure
  11. bct
    bct
    Rcraft, brEad, Tim_with_a_T and 16 others like this.
  12. topher5150
    topher5150
    as long as it holds together I don't care what I looks like.
  13. Nice the way you added adjustability to the alternator bracket, DDDenny.
    ..... and the neatly done clearance notch in the frame. :cool:
    Hackerbilt likes this.
  14. Made these a while back.
  15. phat rat
    phat rat
  16. DDDenny
    Thanks Gary
    I really thought long and hard before I made that cutout in the framerail, was able to (just) get the hoodside to hide it.
    Was also able to bolt the alternator directly to the block and got the pulleys to line up without spacers.
    Just Gary likes this.
  17. Fitnessguy
    Fitnessguy
    barrnone50, fauj, bobbytnm and 7 others like this.
  18. Hackerbilt
    Hackerbilt
    Spring over adapter brackets to move my front axle back. Shortened the wheelbase 4" with these and a redrilled perch bracket. I was able to remove two spacer plates from the perch as well so the T is still the same ride height.
    Friction shocks with working friction pads on both sides of the lever. Work great!
    Right side, low mount Alternator bracket to replace the previous left side setup and delete a wonky idler pulley.
    Windshield posts from sheet steel and an old rusty pipe I found in the pile. The frame is made from some pipe and a slotted 57 Ford truck tierod tube.
    brEad, Tim_with_a_T, alanp561 and 7 others like this.
  19. continentaljohn
    continentaljohn
    The grill inserts I make to go along with the bomber seats I enjoy making image.jpeg
  20. turdmagnet
    turdmagnet
  21. Johnny99
    Johnny99
    Door pulls and door check straps from an door pull 2.JPG door pull 3.JPG door check.JPG old belt a neighbor gave me and some hardware store junk.
  22. 52lomofo
    52lomofo
    did the same to mine
  23. patmanta
    patmanta
    from Woburn, MA
    1. MASSACHUSETTS HAMB
    Ok, I guess I'll chime in with stuff I actually made myself now.
    Subframe:
    SEATS:
    Rear Panel:
    Nose:
    And these shock mounts from the Frame Horns that folks seem to dig:
  24. dumprat
    dumprat
    from b.c.
    IMG_0837.JPG IMG_0963.JPG IMG_1490.JPG IMG_1702.JPG Hand made fuel block, headers, cowl vent ratchet,and some stainless tailgate hinges. I like to make stuff rather than buy it!
    brEad, zzford, mrharley51 and 10 others like this.
  25. RichFox
    RichFox
    I have made a few parts over time. Here is a header flange for a 25 Olds head. First find a piece of scrap large and thick enough (3/8). Cut off everything that doesn't look like a header flange. Ready for pipes. Olds 002.JPG
    Countn'Carbs, brEad, pat59 and 8 others like this.
  26. alchemy
    alchemy
    I make parts that would cost me too much to buy, and have sold some:
    41 Studebaker Taillights
    Pierce Arrow dash panels
    And Stewart Warner Chris Craft panels
    brEad, 40FORDPU, john worden and 11 others like this.
  27. WZ JUNK
    WZ JUNK
    from Neosho, MO
    zgate.jpg A Z gate I made for the column shifter in my truck. It keeps an old man from missing a gear at the drag strip. The pin on the shifter arm fits in the Z gate when you pull it down into low. Slap it up once for second gear and again for third or drive. For street driving you just pull it down into drive as you would normally.
    John
  28. Does this count? I extended the cab on my COE for more legroom.....used another extra cab and some doors....
  29. Automotive Stud
    Automotive Stud
    I wanted to do something clean to cover the A crossmember in the deuce frame under my roadster. My buddy and I made this up to fit the floors I made with a shrinker/stretcher and a bead roller.
