An expansion tank for my T Model Ford Modified. It's made from a fuel pressure reservoir off a Huey and mounts on the spring hanger for the front suicide axle on my Modified using airframe clevis joints from a DC3
I had this old S'OK can on the shelf for 30 years and went to use it one day and it had turned to gel so I found another use for it.
Just an old inert gas canister I found in a scrap bin at work, and a 2" mineralac strap to mount it on the radiator support on the Austin. Found this old tank at a swap meet for $60, and I use it as overflow on my Falcon:
Mine was a piece of aluminum electrical conduit that I had ends welded on to and then turned on a lathe. Blue
cant find picture 1.00 water bottle ALUMINUM from junk store moon eye sticker on it driil and tap top
Yeah, we did, but I'm in the picture postin' mood. You can guess what mine is. Hint: It was made in 1946.
Old fire extingusers ( sp whatever) make cheap aluminum ones after paint removel. Brush fininsh or polish to your liking.
