I have a new steel gas tank, never had gas in it. Should I put a sealer in it first? I remember seeing some POR product for that. Here is what Im sealing.
no no no no no no no no no no no no no no no no do you think you got the answer if not then never never never never never contemplate this move because it fucks your carbs well and true ..........Mad Marq
p.s i gotta say this knowing a bit (a lot) about bikes,how the fuck is that thing ever gonna get around a corner?.............Mad Marq.......p.s thats the point of owning a motorcycle .........corners
I like my bikes to go straight a quarter mile at a time! As far as sealing up your tank, was your tank pressure tested yet? That is a must. There are pros and cons to sealing your tank. Gasoline is not a rust preventative so a unsealed tank will rust from the inside. A sealed tank sometimes is a bandaid for poor welding and a poorly cured sealer will mess with your carbs but then again so will rust. Having the choice I would seal my tank if I knew it was going to be done right. So who are you going to believe? A Brit who is 'oppressed' us as a nation? and builds Triumphs? Or A flag waving American that Builds custom Harleys?
yes you should pressure test it and seal it...my 2 the best is one stop shop at yer local radiator store....that red stuff is forever and bikes are for corners or cool or whatever it is you want man...i dig it
I have built a few bikes, and I still seal all custom or repop tanks.....it's just a hold over from the old days. It can only do good, you don't wanna see fuel dripping on the head AFTER the tank is painted. I use stuff called Kreem..three parts, works great. Actually, mounting the tank is more important than sealing it, no stress on mounting tabs, rubber between tab and frame...this all helps. by the way, that bike looks killer! CT.
Deuce...the tank is from Paul Yaffe. I wasnt worried as much about leaks, more worried about rust. Thanks for the comments, I know some guys at the radiator shop, I think I will take it there monday for the test and seal.
almost guarantee paul yaffee or not it will seep or leak. I use ACE BRAND Marine Spar Varnish in all my tanks....it stands gas [and gasahol] with no probs[years of "tests" here]. takes 2 days dry time before use and costs 7 dollars a quart.....by the way- read the ingredients of the available tank sealer.......[same thing as in spar varnish] less the red dye. {it prob would not work} in an alcohol powered drag car.... he he
I wouldn't seal it. Look how long it took to rust out gast tanks from the 30's -40's. If you wanna check it for leaks, use Isopropyl alcohol and slosh it around. drain it and it will evaporate and leaves no residue.
Marq, There aren't that many corners in the US of A. That why yanks can't ride worth a shit Remember Mr Harley and Mr Davidson? One was born in England, one was the direct offspring of Scottish parents.
I wouldn't seal a brand new gas tank. Rustproblems occure mostly when the car or bike is stored a long time and the tank is empty or half full or something like that. Just make shure to fill your tank to the top if you plan to put the bike to sleep for a while. On old engines I run a little upper lubrication like Marvel or Speedoil once in a while. That helps the gas tank too.
Just an update on the question, Im dropping the tank off tomorrow at a local plater to have it nickel plated, it seems that is the way to go.
[ QUOTE ] p.s i gotta say this knowing a bit (a lot) about bikes,how the fuck is that thing ever gonna get around a corner?.............Mad Marq.......p.s thats the point of owning a motorcycle .........corners [/ QUOTE ] Great the motorcycle nazi is back...
