Should I Grind My WhiteWalls???
Discussion in 'The Hokey Ass Message Board' started by Malarky, Sep 13, 2012.
Grind 'Em...or Leave 'Em Skinny?
Poll closed Sep 18, 2012.
  1. Grind 'Em!
    50 vote(s)
    48.1%
  2. Nah...Leave 'Em Skinny
    54 vote(s)
    51.9%
  1. Blue One
    Blue One
    from Alberta
    Not liking whitewalls does not mean total negativity, just means good taste. :)
  2. Malarky
    Malarky
    <iframe src="http://www.youtube.com/embed/xkcm3rh60p0?feature=player_embedded" allowfullscreen="" frameborder="0" height="360" width="640"></iframe>
    A fellow Hamber made this tech video. Props to Bugman.
  3. Louie T
    Louie T
    I have a set of Firstone FR 380's on my 58 caddy. They have the skinny white walls. I would like to grind them a little fatter. Can I do this with these tires. I know there's some tires that can't be ground down. Ur tires look perfect for my ride.
  4. Kripfink
    Kripfink
    or maybe just bad taste and a tendency to post ill thought out dumb blanket statements.
    Paul
  5. Malarky
    Malarky
    From what I understand any tire with a whitewall or raised white letters can be ground into a www, BUT some brands are better to work with. I've seen some with wavy edges or seams that don't match up evenly. I'm not sure about the tires you have.
    If you are going for the same look I got, don't grind past the bottom of the existing ww. Find the outer edge and blend that to the inner edge of existing ww leaving a bit of a lip or a step on the inner edge.
  6. dad-bud
    dad-bud
    The width you've ground looks spot on.
    The skinny ones you've got on there now are just too skinny.
    JMO
  7. Blue One
    Blue One
    from Alberta
    It's not ill thought out or dumb, I just don't like whitewalls and think the best way to improve the looks of any car fitted with them is to install blackwalls.
  8. HellsHotRods
    HellsHotRods
    wide whites belong on bias ply tires = correct
    regular whites on radials = leave them alone
    Buy the correct tires from Coker for your period correct car.
    Stop messing with the engineered radial tire. Do you want a blow out?
    Is it really worth a blow out to weaken the sidewall of you tire?
  9. Malarky
    Malarky
    Ok. Thank you for your opinion. I think you got your point across. No need to troll.
  10. Malarky
    Malarky
    We mess with the original engineering of cars in just about every way imaginable. I do understand your concern, but I have never heard of a ground ww causing a blow out. I'm sure some old schoolers or more experienced ww grinders can chime in and assure us it really is pretty safe. Removing 1/16" of rubber from the sidewall does not compromise the structural integrity of the tire at all.
  11. Model T1
    Model T1
    I wouldn't fuck with a tire. Buy the ones you want, sell those. :mad:
    Aren't we glad everyone doesn't think alike? If whitwalls sucked why did they last for so many years in so many sizes on so many vehicles?;) Someone besides me musta liked them!
    All of us can't afford to buy special WWW tires or other fancy parts. Traditionally we use what we got! I see nothing wrong with experimenting.
    5" WWW might look nice on your new Prius ! And as long as you like em that's all that matters. :D
    <!-- / message --><!-- sig -->
  12. Blue One
    Blue One
    from Alberta
    Finally ! Not trolling, just think we should respect each others tastes.
    If anyone other than me likes whitewalls, that's fine. Have at it. We should be able to express what we like or don't like.
  13. Deuces
    Deuces
    Man, just buy a set!...
  14. yetiskustoms
    yetiskustoms
    1 3/8 www looks really nice. Im not sure how it would damage your tire if your just takingoff the black over white layer. As long as it is not gouged . Not everyone has the money to just go out and buy a $800 set of tires. If this is your daily, that might be a consideration, but for an every now and then driver I would grind them. All about saving some money. There will always be the what ifs.......
  15. Malarky
    Malarky
    Wow. This poll has been very close from the start with skinny's in the lead by a nose. Interesting.
    You chippin' in?
    Amen.
  16. Gromit
    Gromit
    FWIW.. I like WWs about 1 1/2 to 2 inces.. no need to go full size. Pinners are cool on some cars too. just do what you like, and if someone says it sucks, don't let it bug you too much. Everyone hates my cars lol!
  17. Malarky
    Malarky
    :p I'm sure that's not true.
  18. Louie T
    Louie T
    Sounds like a bunch of malarky to me !!!
  19. Jay Tyrrell
    Jay Tyrrell
    Dude nice job! Wear a mask next time!
    J
  20. Malarky
    Malarky
    Yes he did do a nice job. I watched this video before I tried grinding my own. And your right about wearing the mask.
  21. Malarky
    Malarky
    Your 61 Belair looks awesome with those tires on it! Way better than the blackwalls. Did you make 'em or buy 'em like that?
  22. n847
    n847
    I think the size tire you ground would look perfect with your stance! Then again opinions are like ass holes we've all got one!
    I decided against WWW when I decided not to go with a custom look on my Plymouth but If I had used them on my budget I would have done them the same way! Good luck!
  23. Malarky
    Malarky
    Right-on man. Thanks.
  24. Malarky
    Malarky
    BTTT Poll ends Tomorrow.
  25. ONE8SEVEN
    ONE8SEVEN
  26. ONE8SEVEN
    ONE8SEVEN
  27. Lone Star Mopar
    Lone Star Mopar
    Fuck the poll, just DO IT DO IT
  28. Malarky
    Malarky
    HAHA. Its really interesting to see what you guys think. I like the way skinny's look, But I'm still leaning towards trying out grinding a set. We'll see.
  29. Malarky
    Malarky
  30. Engine man
    Engine man
    from Wisconsin
    How do you think the tire companies make whitewall tires? I'll give you a hint, they grind them.
    As the picture shows, the big Mercs came with pretty much the same width you ground and it looks good on them. Narrow whitewalls were on the sportier cars.
