Projects Setting up motor mounts
Discussion in 'Traditional Hot Rods' started by 65standard, Jul 24, 2020.
  1. 1B089EA4-7422-4E3C-97F5-50DC2524D110.jpeg I’m building a ‘32 3-window and I’m using a ‘39 flathead and trans. Is the flathead set level in the frame or is it angled down like a modern car?
  2. Departed
    Departed
    from Canada
    I think what defines the angle of an engine is the carbs…as far as I know, the carb has to sit level. the rest fallows.
    MO54Frank likes this.
  3. el Scotto
    el Scotto
    from Tracy, CA
    If you look through the crank hole in the grill you should see the front of the crank. ;)
    LOU WELLS likes this.
  4. V8 Bob
    V8 Bob
    The '32-'48 torque tube cars all have the engine level, along with a flat carb base. Beginning in '49, Ford/Merc cars switched to an open driveline and hypoid 3rd members which allowed a lower drive shaft by angling the engine down a few degrees in the rear, along with angled carb bases on the intakes to bring the carbs back to level.
    Nailhead Jason likes this.
  5. Heres my 8RT leaning down at the rear. ( see level brickwork ) mounting surface for carb on a standard intake is level with this setup .
  6. lostone
    lostone
    from kansas
    Yeah I always run the intake manifold carb flange level and go from there....
    WB69 likes this.
  7. V8 Bob
    V8 Bob
    A lot depends on the car's ride height. For example, the 8BA in my open drive '32 is angled about 4 degrees down, but the chassis sits about 3 degrees down in front, so the 97s on my early flat style Navarro intake are close to level.
    If you intend to use a stock '32-'48 Ford rear mount with an open drive, you may find it difficult to attain good U-joint angles without raising the front of the engine.
  8. chop job
    chop job
    from Wisconsin
    1. WISCONSON HAMBERS
    WHAT YA MEAN.
  9. jimvette59
    jimvette59
    Are you using a 32 cross member that the transmission mounts to ?
  10. B9132F48-7774-44E1-ACDE-722DF69C0595.jpeg I’m using a 1940 trans mount??? Not exactly sure of the year.
  11. I’m also using the stock torque tube.
  12. alchemy
    alchemy
    With that X member and trans mount, you can do whatever you want. But, most aftermarket flathead intakes are flat. If the car has a 3 degree nose-down rake to the frame, then put the engine at a 3 degree up. Then the carbs would be flat. But it doesn't really matter much anyways, because Strombergs hinge the floats from the side so a rake won't effect them.
  13. el Scotto
    el Scotto
    from Tracy, CA
    That little hole at the bottom of the grill is where you are able to use a hand crank to start an original car. It needs to line up with the crank to work.
    It was more of a tongue-in-cheek comment but technically still true...
