Trying to contact Okie Joe via phone and email to no avail. Is there any one else out there that can tweak a '32 heavy axle as the camber on the driver's side is out at least 5 degrees.
Both Joe and Sid may be off at swapmeets or other events as Sid was headed to Hershey earlier in the week. Most likely there is a local to you shop that works on springs and usually heavier trucks that can correct the camber but the issue there may do it in a way where the axle looks tweaked a tad rather than keeping the smoot flow of the drop as one of the drop axle shops should.
