searching for six volt windshield 'squirters'...
Discussion in 'The Hokey Ass Message Board' started by tred, Oct 30, 2004.
  1. tred
    tred
    y' know, the device that squirts washer fluid onto the windshield, where can i find these things?
    i am having no luck searching the old fashioned way...
    help?
    tred.
  2. yorgatron
    yorgatron
    back in the 6 volt era most cars had vacuum squirters-george
  3. Paul
    Paul
    Editor
    how about using the manual pump type?
    sixties Mustang comes to mind..
    Paul
  4. tred
    tred
    my apologies, i'm looking for the electrical type...
    i heard that checker used to put them on the cabs, but i couldn't yet verify that.
    i know that the checker had a 6 volt alternator as early as 1948, but can't find windshield squirters.
  5. tred
    tred
    tell me more about this manaul pump mustang thing, this is a joke, right?...
  6. daren
    daren
    Tis true. I had a 67' Mustang, each time you pumped the pedal it would squirt you're windshield washer nozzles. I understand the early cougars had the same system. No electricity or vacuum required.
  7. Rocket Scientist Chris
    Try searching for Trico brand washers. They were common equipment in alot of 50's cars. Also take a look at Wiper Man.
    [ QUOTE ]
    [/ QUOTE ]
    I always thought Chrysler developed the alternater and introduced it late in 1959 on their new 1960 models. [​IMG]
  8. Fat Hack
    Fat Hack
    from Detroit
    I have an old manual windshield washer 'pump'. It mounts to the floor with a metal bracket, and you step on it as needed to pump washer solvent up through the squirter nozzles. Usually mounted down near the dimmer switch.
    I could probably dig it up if anyone was really interested in it.
  9. old beet
    old beet
    My 63 Fairlane had the pump pedal on the floor, stock.....OLDBEET
  10. Have you tried hooking up one of those 12v windshield washer pump motors to your 6v battery to test the flow of water output?? I'm thinking that the windhield washer pump is just a small motor so a 12v unit should still work on 6v, but it will probably be a bit slow water spray??maybe, not too sure. If this is the case, you might be able to make a smaller hole in the output nozzle to restrict water flow, and increase the pressure giving an OK spray on your windshield. worth a try i guess [​IMG] gotta be easier than trying to locate a 6v unit eh??
    Paul
  11. Paul2748
    Paul2748
    54 Fords also had a pump pedal for the window washers. I assume 52-53 had them also
  12. tommy
    tommy
    [ QUOTE ]
    [/ QUOTE ]
    it ain't no joke [​IMG]
    [​IMG] [​IMG] [​IMG]
    What voltage is your finger? [​IMG]
  13. nero
    nero
    no joke,,my 631/2 falcon sprint had the sam unit shown,
  14. noboD
    noboD
    VW used a air pressurised bottle up into the '70's. No voltage needed.
  15. oldchevyseller
    oldchevyseller
    from mankato mn
    [ QUOTE ]
    [/ QUOTE ]yes but the air came from the spare tire with a hose to the bottle, [​IMG] you cant just fill it up with air
  16. It seems I always come up with suggestions from foreign car sources, but, consider; foreign cars are small, early cars are small.
    Anyway - my Citroën 2CV has a dash-mounted plunger pump which would work rather well in your case. Spray can be adjusted by the pressure by your finger. The picture says it all as for appearance:
  17. swazzie
    swazzie
    [ QUOTE ]
    [/ QUOTE ]
    It's true tred , I had a 65 fairlane with this .It had a lever under the dash and a bag on inner fender.like this. You see them on ebay periodically and they are not too expensive .swaZZie
  18. Paul
    Paul
    Editor
    back to the original question,
    how about looking at big cars of the early '50s?
    Chryslers, Cadillacs, Lincolns?
    seems my '52 Saratoga had squirters but my memory aint so good..
    Paul
