Projects Seagrave 531 V12 Special BuiLd Up in Brazil
Discussion in 'Traditional Hot Rods' started by Drmalacarne, Sep 5, 2019.
  1. 282doorUK
    282doorUK
    Oh that must have been hard to take, how many hours had it run before you noticed a problem?
    loudbang, Deuces, Thor1 and 2 others like this.
  2. rusty valley
    rusty valley
    sorry to hear this, maybe while its apart you can lighten up some things to make it less of a truck engine?
    loudbang, Deuces, Thor1 and 1 other person like this.
  3. Drmalacarne
    Drmalacarne
    Not for so long. Maybe 10 or 12 days os use.
    Enviado do meu iPhone usando H.A.M.B.
    40two, loudbang, Deuces and 3 others like this.
  4. Blues4U
    Blues4U
    from So Cal
    It will go together quicker the 2nd time! ;)
  5. Was there any damage to the crankshaft? The whole thing severely sucks but you and your crew are motivated and dedicated. That has been evidenced from the beginning. Best of luck and hope it all comes out better this time.
    weps, loudbang, Deuces and 4 others like this.
  6. Stogy
    Stogy
    It's missing most of the Fire Truck/Big Auto Shell so its already I imagine quite a bit lighter than a Stocker...but this is how Racers probably think of things...
  7. rusty valley
    rusty valley
    Good point Stogy, and with most of the old long stroke motors high RPM is an enemy. but..how about a lighter flywheel?, or maybe even rods? depends on how much more time and money one wants to spend. But, really the car is already serving its purpose just fine, it f'n cool as shit!!!!
    weps, Thor1, chryslerfan55 and 3 others like this.
  8. j hansen
    j hansen
  9. tubman
    tubman
    I hate to see this, especially after all of your effort. The first thing that entered my mind is if there is any source for the parts you need; bearings, etc.; heaven forbid you need a crankshaft or some other major part. There is an organization in the states called the "Society for the Preservation and Appreciation of Antique Motor Fire Apparatus in America" (SPAAMFAA) that has many members with a lot of resources.
    It might be a source if there are no others. (You may want to keep what you are doing a secret if you contact them.)
    Stogy, Thor1, chryslerfan55 and 4 others like this.
  10. The guy built this big beautiful car mostly from scratch in his own shop. I think he can get the engine going just fine.
    Jet96, Hnstray, BradinNC and 11 others like this.
  11. I haven't been on the HAMB much in the last year, but just saw this and it made my day! What a great effort all along and the results are amazing. Hope to see it back on the road again and hopefully take us all along with a good video!
    Stogy, Thor1, chryslerfan55 and 3 others like this.
  12. From the looks of the bearings, it appears that it did not have enough oil lubrication - as I noticed the rod bearings were worn as well. Did you find an oiling issue by chance?
    Stogy, Thor1, Blues4U and 3 others like this.
  13. Rickybop
    Rickybop
    @Drmalacarne
    Just stopped in to see the latest.
    Oops... a little problem.
    Sorry about that. Good luck with it. Lots of confidence that you can fix it. Knowing you, you'll make it even better.
    Stogy, loudbang, Thor1 and 2 others like this.
  14. Drmalacarne
    Drmalacarne
    The oiling system looks ok.
    We used the engine a lot before we noticed the wrong sound.
    The ussue we believe is the bearings materials.
    Thanks.
    Gui
    Stogy, loudbang, Thor1 and 1 other person like this.
  15. That certainly looks painful. :eek: Though I guess that's just one of the risks you take when running a high performance racing engine. With everything stripped off the top of the motor like that, the crankcase looks absolutely too small and frail. o_O
    But to me the worst part of the job would be reinstalling the distributors and routing all those plug wires!
    :rolleyes:
  16. "Hi performance racing engine"??
    Jet96, Runnin shine, ottoman and 3 others like this.
  17. fresh hops
    fresh hops
  18. Ebbsspeed
    Ebbsspeed
    Ouch! Do you know the history of the engine, and did you look at the bearings before you ever ran it?
    weps and Thor1 like this.
  19. LOL! Maybe I should have stuck a few more :rolleyes: :rolleyes: :rolleyes: in my previous post.
    :p
    I don't imagine that the original engineering for this motor paid any real consideration to oil pan baffling or high speed cornering . . . :D
    weps, loudbang, chryslerfan55 and 5 others like this.
  20. Rickybop
    Rickybop
    He's been all through this engine and I believe he MADE the bearings. I think that's why he mentioned he was thinking that the material they're made from could possibly be the problem.
  21. Drmalacarne
    Drmalacarne
    Yes Ricky!
    We custom made the bearings.
    And we believe the materials didn’t meet the ideal criteria.
    Gui
  22. Rickybop
    Rickybop
    Hey, @Drmalacarne ...
    Did you make the bearings out of solid steel? No coatings? I'd like to think that if all the dimensions and the oiling are good, the bearings could be made out of almost anything that's hard enough. But I guess the soft outer coating is pretty important. This time around, after the bearings are machined, I wonder if it would be a good thing to have them sprayed/plated with a thin coating of zinc or something similar? Maybe even one of the modern dry lubrication films they're using these days? Although, I think that the zinc coatings provide some cushion that a dry lubrication coating can't.
    Drmalacarne, Thor1, loudbang and 3 others like this.
  23. Rickybop
    Rickybop
    Or maybe machine the block and/or the crankshaft to accept standard manufactured bearings?
    Thor1, loudbang, 41 GMC K-18 and 2 others like this.
  24. Rramjet1
    Rramjet1
    I stumbled on this thread and spent the last couple of hours reading through it. Amazing work! The creativeness and cleverness in solving what would be insurmountable problems for some was impressive. Sorry for the recent misfortune but I’m certain it is just a minor stumble and you will be back on the road before we know it.
  25. Drmalacarne
    Drmalacarne
    That’s the way wi will go Ricky!
    Thanks. Gui
    Rickybop, loudbang, Ned Ludd and 4 others like this.
  26. fonti
    fonti
    Hey Gui
    what a great thread...congratulations! I am very sorry about your engine but you will get that fixed...
    keep up the great work you do,
    all the best from Switzerland!
    Peter
  27. Drmalacarne
    Drmalacarne
    DABB8F51-2B18-4CD2-B616-26D3E4D4DE4D.jpeg 86B2F1A5-1FAA-4675-8C7B-3DBFD52BDC7C.jpeg F32417AC-B557-41F4-895F-158C1A595CE1.jpeg BD18387D-21AA-47B8-BCC3-F49266727A2B.jpeg 33D3CF3C-D38C-4885-BF2D-F59837908641.jpeg 6B7CE693-CA4C-404A-BA3D-CB8081A7CC09.jpeg A7D87BE4-77E6-4678-B58B-9CAC19A07FDC.jpeg ADEB061E-7F9C-48C0-B0CD-059FB797697E.jpeg E37F72E5-9E09-4780-8B11-980BAA6049F7.jpeg 696E4E94-B822-497C-87F1-33E2049E392B.jpeg D7F0051C-1E56-477E-BE32-FE9173CBF2AA.jpeg 1588CE90-A8A6-477F-86AB-B29C2FD92469.jpeg C89A9076-E089-48EA-8071-A262A48B0C58.jpeg DABB8F51-2B18-4CD2-B616-26D3E4D4DE4D.jpeg 86B2F1A5-1FAA-4675-8C7B-3DBFD52BDC7C.jpeg F32417AC-B557-41F4-895F-158C1A595CE1.jpeg BD18387D-21AA-47B8-BCC3-F49266727A2B.jpeg 33D3CF3C-D38C-4885-BF2D-F59837908641.jpeg 6B7CE693-CA4C-404A-BA3D-CB8081A7CC09.jpeg A7D87BE4-77E6-4678-B58B-9CAC19A07FDC.jpeg ADEB061E-7F9C-48C0-B0CD-059FB797697E.jpeg E37F72E5-9E09-4780-8B11-980BAA6049F7.jpeg 696E4E94-B822-497C-87F1-33E2049E392B.jpeg D7F0051C-1E56-477E-BE32-FE9173CBF2AA.jpeg 1588CE90-A8A6-477F-86AB-B29C2FD92469.jpeg C89A9076-E089-48EA-8071-A262A48B0C58.jpeg BBCD25DC-50F4-43FA-97C0-8F81ADD21C15.jpeg 350071DC-2A89-4575-B72D-1A16DE113733.png 2FECE756-18C1-462C-8F92-120EDD6FB1E0.jpeg F8F4B897-F233-473D-AB72-7F28ACAD50AE.jpeg Hi friends
    Sorry for the long absence.
    The V12 Seagrave Speedster now has the engine perfect with the bearings fixed, a electric fuel pump, open giclês in the Zenith carbs and a ultra faithfull Optima Yellow Top battery.
    Now the local rides becomes easy and peaceful!
    Here are some pics.
  28. Outstanding build, you are a legend Gui :rolleyes:
    Boneyard51, loudbang, Deuces and 5 others like this.
  29. 41 GMC K-18
    41 GMC K-18
    Outstanding indeed !
    So glad that there is this cool update on the " LEVIATHAN "
    Perfection cannot be rushed !
    Thanks for posting these cool photographs.
    Dennis.
    Deuces, Thor1, Drmalacarne and 3 others like this.
  30. Stogy
    Stogy
    Stunning finale to a most interesting build...Thanks so much for sharing the journey @Drmalacarne...
    Happy New year to you and your team...
