Hot Rods Scored a flathead last night
Discussion in 'The Hokey Ass Message Board' started by Kevin Ardinger, May 8, 2020.
  1. Kevin Ardinger
    Kevin Ardinger
    Not sure what I’ll do with it but I am now I flathead owner. Lol. Probably build it and put it in something. No visible cracks, adjustable lifters. I’ll send it to the machine shop at some point and have it checked.
    Desoto291Hemi and J_J2 like this.
  2. 41rodderz
    41rodderz
    from Oregon
    There you go. Will make a cool little power plant.:)
  3. mickeyc
    mickeyc
    I notice it has an integrated bellhousing. What letter and
    numbers are reflected in the casting at the top of the bell. I have a flat head with 59L cast in that location.
    It has been suggested that the 59L blocks were relieved
    at the valve area. I have not removed the heads on my
    motor and wondered if yours might be a 59L. If so is
    the block relieved?
    Desoto291Hemi and kidcampbell71 like this.
  4. Make sure you get the main bearing caps with it.
  5. rusty valley
    rusty valley
    just a wild guess here, but its a pre 8ba block, but the pulley on the crank looks narrow belt and big clean out. that would be the 4" stroke merc crank.
  6. Hotrodmyk
    Hotrodmyk
    1. Northwest HAMBers
    @mikeyc I had a 59L and it was relieved.
  7. 19Fordy
    19Fordy
  8. leon bee
    leon bee
    I see the caps on that shelf. Also, remember you probably don't want to mount that thing on an engine stand in the usual way.
    Flathead Dave likes this.
  9. Kevin Ardinger
    Kevin Ardinger
    Just 59 on the bell housing. I have the main caps. Supposed to be a 59AB? 1948? This is all new to me. Friend went with me that knows quite a bit about them. He said it was one of the cleanest ones he had seen.
    How would I Id the crank? Pistons have STD stamped on them. I assume they are replacement Std bore.
  10. 19Fordy
    19Fordy
    Look carefully on the bearing caps and the block to see if the caps and block were stamped with
    matching center punch dimples indicating their location and direction of installation.
    For instance: 1 center punch mark of the block and 1 center punch mark of the cap for front bearing cap. Then the same for bearing caps 2,3, and 4. Read through this info.
    https://www.google.com/search?q=how...e..69i57j33.5719j0j4&sourceid=chrome&ie=UTF-8
    lothiandon1940 likes this.
  11. Kevin Ardinger
    Kevin Ardinger
    dan c likes this.
  12. 19Fordy
    19Fordy
    Only 3 main bearing caps on a flat head. Sorry for the confusion.
    Main bearing and rod bearing caps should all be marked so they fit the same way
    as when installed by Ford.
  13. mickeyc
    mickeyc
    Thanks for the comment. I have received a lot of conflicting information regarding the origins of 59L
    motors and their placement.
    Hotrodmyk likes this.
  14. rusty valley
    rusty valley
    if the crank has two oil ports on each rod journal, its a later 8ba or merc. if the clean out plug on the end is big 5/8" i think, its merc, if small , like 3/8, its ford. if its the skinny 3/8 fan belt pulley, its not stock for a 59 series block
  15. Kevin Ardinger
    Kevin Ardinger
    Gotcha, thanks I’ll check those things.
  16. Kevin Ardinger
    Kevin Ardinger
    Thanks for the info. I’ll check all that stuff and see what it’s got. Are the stock heads and intake good for anything?
  17. dan c
    dan c
    it looks like the exhaust ports are opened up...
  18. 19Fordy
    19Fordy
    Also, buy the best books on rebuilding a flathead Ford engine BEFORE spending tons of dough. Rebuilding a flathead is costly, especially if you pay someone else. Aslo, rebuilding a flatty to stock specs will still provide you with a peppy little engine that runs cool.. Remember, it must run cool. Make a plan and stick to it. Speed cost money. Are there an experienced flathead engine builders in your area? You don't want someone "to learn how" on your engine. Find someone who has done it before and can give you advice. Also, don't throw anything away until your engine is done and running.
    Peruse all this:
    https://www.google.com/search?q=how...69i60j69i61.8024j0j4&sourceid=chrome&ie=UTF-8
  19. alchemy
    alchemy
    Mismatch of parts. Looks like a late front cover too.
    Isn't that an Auburn clutch?
  20. Hotrodmyk
    Hotrodmyk
    @mikeyc My particular 59L came out of a '40 Merc, had a 99A serial number stamped on it. Like yourself, I can't tell you all the stories I have heard about 59L's.
  21. Kevin Ardinger
    Kevin Ardinger
    There are a couple of good machinist in the area. I would actually like to build the engine myself. Just a little more peppy than stock.
  22. alchemy
    alchemy
    This is interesting. Where was the serial number on the engine? That's not usual Ford procedure.
    All 59 designation blocks were designed in 1945. That's the 5 in 59. So the 59L that was in the 40 Merc was installed at a later date. Maybe the mechanic thought it would be a good idea to transfer the serial number to the new block.
  23. tubman
    tubman
    Since Ford didn't stamp their V8's, this is a no-brainer per "alchemy".
  24. Hotrodmyk
    Hotrodmyk
    I believe you are correct. It was stamped on the intake manifold surface of the block. in the left rear.
  25. rusty valley
    rusty valley
    i think some states required it
  26. mickeyc
    mickeyc
    I have been informed the 59L was a factory
    replacement motor. Also was told they were truck motors and ford incorporated the block reliefs to
    give trucks a bit more grunt? The motor I have is installed in a 32 chassis and has been there before the owner I got it from bought it in the late fifties. Even the fellows atH&H flatheads could not define the origins of 59Lblocks. I am not really concerned regardless. I had no intention to use the motor, although it turns nicely with the starter motor. I did see a cell phone video of the motor running smoothly as I was told. I now am reconsidering using the motor if indeed it does run well. The entire drive train is in functioning order as far as I can tell from seeing videos of the car driving before the body was removed to put on a typical street rod chassis and all that implies.
    I hope Kevin can enlighten folks as he proceeds with his 59 motor.
    kidcampbell71 likes this.
  27. 19Fordy
    19Fordy
    Ford flat head engines did not have serial number stamped or cast into them. The only number is the one cast into the engine block to designate the era of its manufacture. The only exception to this is that some later 1949-53 Mercury (8BA era) blocks did have a date code number stamped into the machined surface at the front where the intake bolts on. It's covered by the intake. Read about it here:
    http://myflatheadford.com/5988-2/
    Please take the time to read all the flathead ID info obtained on Google. Very informative.
    https://www.google.com/search?q=fla.....69i57j33.10871j0j4&sourceid=chrome&ie=UTF-8
  28. Kevin Ardinger
    Kevin Ardinger
    Probably be a while before I start on this. Still finishing the Model A with a SBC in it. LOL
  29. 19Fordy
    19Fordy
    Great! Just be sure to stuff all the flat head info. you can into your head
    so that you spend your money wisely.
    Kevin Ardinger likes this.
