Old Schroeder sprint car steering box. I bought it 20 years ago and it’s been sitting around taken apart. I ended up picking up a nicer one, so I’m selling this. It was taken apart for shipping so I put it back together tonight to make sure I had all the parts. I believe the only thing it needs is a sector shaft grease seal at the end of the tube where the steer arm bolts on. It’s dry, so it will need grease also. The sector shaft had a touch of runout, so it has a slight drag on one spot when you spin the shaft by itself, however with the gear ratio reduction, you can’t feel it when you spin the pinion shaft.
