I'm welding the patch panels in my coupe and I have questions on the proper way to use the hammer and dolly. I've searched and everything says to scretch the weld beads after they shrink. Nothing tells the technique they are using. Do I need to hammer the welds when the are still hot? When I chopped the top I would hammer the welds from the backside with the dolly on the outside. From what I read this seems backwards. How do I scretch the bead if I hammer from the outside? Also I'm using a TIG. thanks Mat
Okay,enough of that. It takes practice to get the technique just right. The learning is in the doing. Have at it....
Hey, When it comes to hammer and dolly use, you're lookin' at two techniques: hammer on dolly, and hammer off dolly. To stretch a welded bead, the hammer on technique is used. Any time you are hitting the metal with a hammer above, and dolly below (metal inbetween) you are stretching the metal. The off- dolly technique will move metal, but not stretch the metal as the on dolly will. Your sucess at hammerwelding a tig bead , which is what the technique of hammering on a weld is called, will have alot to do with what filler rod you're using. You can hammer the welds cold as well as red hot. When you pick a dolly for hammerwelding, try and pick one that matches the shape of the panel you're weld- ing. The dolly is held firmly under the weld (best when still red hot) and struck with a wide faced body hammer, from above. The idea is to shape the weld and surrounding metal to the same thickness and uniform shape. Done properly, little or no filler should be neces- sary. Swankey Devils C.C. "Meanwhile, back aboard the Tainked Pork"
Thanks pimpin paint. Just one question what filler rod should I be using? I'm using 1/16 mild steel rod not sure of the aloy. I see that some guys are cutting strips of sheet metal or using .035 MIG wire. Would you recommend either of these? thanks Mat
Hey Mat, I've used rod with a AWS# (American Welding Society Number) , as sold for gas welding, strips cut from the parent metal, and "genuine" virgin coat hanger wire, all with great results. I haven't tried to make "mig'' wire work, as it is alittle hard to forge, onced cooled. What you're after is a welding wire that is roughly the thickness of the sheetmetal you're tring to weld together. good luck, Swankey Devils C.C. "Meanwhile, back aboard the Tainted Pork"
