SBC Z-28 305 c.i. motor. "Rebuilt" with 3,800 mile's. 'NEW PARTS" K & N 8" s/s air cleaner on a Holley 600 cfm carb. Edelbrock Torker II aluminum intake manifold. Crane 1.5 ratio roller rockers. Stud girdle. Comp push-rod guide plates. Polished "finned" aluminum valve covers. Polished finned aluminum valve cover breathers. polished aluminum valve cover extend-spacers. New chrome winged valve cover hold-down bolts. New intake gasket set. New rear main seal. New m-77 high pressure oil pump. New pan & pan gasket. New Hei billet aluminum distributor with 65,000 volt coil. New red Accel extended boot 8mm. spark plug wires. new ac delco spark plugs. New Holley chrome fuel pump. New high pressure fuel line & s/s #10 micron fuel filter. New 3-groove Polished aluminum crank pulley. New Hi-volume water pump. New 168 tooth balanced flex plate. New Arp flex plate bolts. New Advanced-tech torque converter & bolts. Sanderson ceramic coated (inside & out) sprint style header's with 8" in-collester Baffels. Block has motor mount casting bolts on side & front of block. With all new bolts. NOTE: ( I had this motor in my '56 f-100 daily driver. I replaced it with a 377 ci stroked fuel injected vortex sbc. This is a sweet sbc with some Hi-performance parts, great on gas and looks the part. out and ready to go. just the hi-performance parts alone were more than i'm asking for this motor. (Can't load pic's) Pictures on request, send e-mail. $1,650.00 OBO. [email protected] Tel: #631-326-7510 DEPUTY 30 (RANDY)
