Hot Rods SBC overheating...yes I've tried almost everything!
Discussion in 'The Hokey Ass Message Board' started by 55panelwagon, Apr 28, 2017.
  1. Not magic ..just adequate radiator, and air flow through it.
  2. Fordy Frd
    Fordy Frd
    Interesting reading thru all of this. I had heat issues in my '48 Ford Coupe as well sitting and idling, at highway speeds the temp was only 160*! I changed out the high flow thermostat to a standard 180* unit. Changed the fan to a 6 blade steel fan, found that the flex fan was quite noisy. But by far the best thing I did was install a fan shroud! Now temp stays around 180 - 185 all day, city or highway. Just my 2 cents
    pat59 and jeffd1988 like this.
  3. gimpyshotrods
    gimpyshotrods
    Gasoline horsepower and electric horsepower are not rated in equal fashion.
  4. skip57
    skip57
    from md.
    Thank God I did not have to read 15 or 16 pages of crap!!!!!
    Yes I read all that came up 8 pages.
    Set your timing at the max advance as you were told.
    All you need now is an automatic control for the puller fan. And a over flow catch can so you don't puke antifreeze.
    Your engine runs at 195 deg. if your puller fan & rad. can't maintan that you may need a larger Rad.
  5. Moriarity
    Moriarity
    SUPER MODERATOR
    this must be fixed now as the vehicle is for sale on ebay......
    swade41 and flatheadpete like this.
  6. flatheadpete
    flatheadpete
    from Burton, MI
    Nice.
  7. jimmy six
    jimmy six
    Just passing on a problem....ill just ignore anything from 55panelwagon from now on..
  8. I thought it was still torque over time.
    What's the conversion factor ?
    '49 Ford Coupe likes this.
  9. Ignored
  10. Or not fixed....
    belair likes this.
  11. Gman0046
    Gman0046
    The HAMB ought to get a commission soon the sale.
    Moriarity likes this.
  12. 55panelwagon
    55panelwagon
    The problem is fixed and I do appreciate all the help from you guys. Just found out I have to pay a large chunk of change for nursing school next semester so I have to sale the panel. I am glad you guys could help me out as I would've never figured it out on my own. Life happens and selling this to pay for nursing school is more important for my son and I.
    Once again, thanks for all the advice and helping me solve my problem. I still believe this is a great forum and I'm sorry if by me deciding to sell my vehicle that has made you guys mad. Thanks again.
    55zephyr, belair, Hatchet and 3 others like this.
  13. leon bee
    leon bee
    It's a nice truck, kinda wish it was mine. Got too many other projects waiting.
  14. 55panelwagon
    55panelwagon
    Thank you!
  15. jeffd1988
    jeffd1988
    Hopefully you get another one soon. Or something. But life happens. Good luck. great thread and yes I should read all details lol.
    Sent from my Z981 using The H.A.M.B. mobile app
  16. jimmy six
    jimmy six
    How was it fixed? Or which idea worked?
  17. 55panelwagon
    55panelwagon
    I removed the fan that was incorrect for the reverse flow water pump. I added a high CFM electric fan, changed the thermostat and radiator cap as suggested, burped the system of air, and added an overflow line.
    Hatchet likes this.
  18. BJR
    BJR
    Good to here, now we can put this thread to rest, finished, sold, done, nothing more to be said!!!!!
    jeffd1988 likes this.
  19. I bought a car, wouldn't warm up (in the winter), finally figured out that the previous owner had mixed antifreeze. He had added green to pink. At that time the mixture had a chemical reaction that ate up the plastic H2O pump blades. Drained & put in fresh antifreeze = problem solved.
    Good luck.
  20. 32pdx
    32pdx
    Unintentional post, deleted.
  21. lippy
    lippy
    from Ks
    I won't come see you with a temperature. Lippy
  22. Look at how the air under the hood behaves, it's got to come in thru the radiator not over the top of the core support, and exit thru the rear of the fenders there should be a metal piece from the top of the core support to the hood to prevent hot air recirculating back in front of the radiator and clear open area for the air to exit at the lower rear of the engine compartment.
