any experts here ? i looked all over the internet and cant find out what size valves ive got , casting number is 383487 small block chevy
I think you're missing a number somewhere, but a "383" being the first would indicate a 55-57 265/283/327
Those are mid 70's 350-400 SBC heads. They are usually around 74cc and they are good flowing heads. I have seen them with 1.94's and 2.02's
ok , one head was missing a 7 , so the correct # is 3973487 , sounds right because the block # is 3970010 , thanks for the help guys !
Got this from Chevymania. Could have either set of valves. 3973487 350 68-79 1.94/1.50 2.02/1.60 76cc
That makes more sense! Those are good heads. 3973487....71-72...350..........1.94/1.5 or 2.02/1.6 valves, was also used on '71 350/330hp LT1, 75cc chamber
I will throw my 2 cents The 487 heads are made 2 ways. ealy 487 no heat treat for unleaded late 487X with heat treat Van
I had a set of them on a 383, ran damn fine, breathed surprisingly well for what were supposed to be undesirable 'smog' heads... in fact, still motivates my pal's 50 Stude PU very well!
The 487X would be just as I type it with the X right after the 7. The 487 and the 993's are big chamber heads but are considered very good flowing and power making heads. 882's and 624's not so good. Van
they do have screw in studs and guide plates , but i just assumed somebody added them later , maybe not ! the guy i bought it from did claim it was an LT-1 but i just figured he was full of shit
