Technical saving an old Navarro intake
Discussion in 'Traditional Hot Rods' started by FlatJan, May 14, 2019.
  1. FlatJan
    FlatJan
    Hey Guys,
    I'm more kind of a silent reader, collecting ideas, asking silly questions and learning.
    but now I got something that might be interesting for you so i wanna give a little bit back to the community
    some time ago i bought an old dog bone intake here on the hamb. No bone on it just a cap.
    being curious i wanted to look under it and then stuff fell apart. Badly helicoiled as it was it wasn't possible to screw it back together.
    ok so let's fix that thing as they are no so often found. Bored out the helis, parts broke of,a mess bigger than expected
    welded some aluminum into it and filed it down by hand, taking care of keeping it level to the carbs mounting surface cause if i find a bone i wanna use it.
    this is when i took the first photo
    kidcampbell71 and ChuckleHead_Al like this.
  2. FlatJan
    FlatJan
    here ya go
    Deuces and kidcampbell71 like this.
  3. FlatJan
    FlatJan
    checking with the cap
  4. FlatJan
    FlatJan
    ready for making holes
  5. FlatJan
    FlatJan
    cleaned up the inside and drilled it. Then tapping that baby
  6. FlatJan
    FlatJan
    drilled out the rest of a helicoil from the cap.
    Finally not that bad... Maybe will blast it and bolts need some patina :)
  7. FlatJan
    FlatJan
    ...and this is where its gonna go, replacing the actually mounted Navarro "super" dual,
    paired with new Navarro heads on my French Flatty
  8. Nice save! I'm not familiar with that intake. What is the "bone" of which you speak?
  9. J. A. Miller
    J. A. Miller
    from Central NY
    I think in this case it was a wishbone - as in he wishes he hadn't bought it. :rolleyes:
    Deuces likes this.
  10. FlatJan
    FlatJan
    kinda wish i had one ;), but they are available, its the heat spreader for the exhaust gases which bolts on top of it and goes even under the carbs. There are other threads with picshere on the hamb
    Deuces likes this.
  11. moonlight graham
    moonlight graham
    from wyo
    Jan, Definitely worth picking up a dogbone from Mike Herman at H&H
    Geoffrey
    Elcohaulic, Deuces, FlatJan and 2 others like this.
  12. tubman
    tubman
    Looks like it might be good for us guys up here in Minnesoooota if we drive our hot rods in the winter!:D
    jimmy six likes this.
  13. Think I have the same intake - that was made into a three / two......but lucky to get the real deal as well... pics later...
  14. Squablow
    Squablow
    Never saw one of those before. Glad you were able to save it, well worth the effort.
    FlatJan likes this.
  15. FlatJan
    FlatJan
    ok, got some more progress onmy favorite intake.
    Someone, whysoever, cut up the gen-mount so i tried to rebuild it. Made some filler pieces, but they really welded up crappy[​IMG]
    finally welded everything shut with welding rod. yes i know i´m not the greatest aluminum welder in the world. but hey i´m a hell of a grinder ;)
    and cut it down on the mill
    yeah not really where i wanted it...
    Memphis235 and Tman like this.
  16. FlatJan
    FlatJan
    so lets put some more rods in that poor old thing
    after the second "mill" i liked it a lot more
    blasted it finally and it looked a lot better
    found some interesting little holes in the carb bases. Don´t know what they are good for. Maybe somebody knows?
    1952henry and kidcampbell71 like this.
  17. COCONUTS
    COCONUTS
    Nice work, I am surprise that you did not just buy an NOS one from Sears. Only joking, good job.
    Deuces likes this.
  18. They look like prick punch marks, probably used to keep the gasket in place.
    ottoman, Deuces and jimmy six like this.
  19. x77matt
    x77matt
    Wow! Really awesome work there! Love to see the talent on here- especially to save something that most would consider un-savable.
    FlatJan and Deuces like this.
  20. HotRodMicky
    HotRodMicky
    Looks good , Jan !
    Do you have the dogbone, too?
    Regards
    Michael
  21. FlatJan
    FlatJan
    Hey Michael
    good to read you ;)
    No will have to buy it
    Greetings
    Jan
