Saving a 32 Ford Body
Discussion in 'The Hokey Ass Message Board' started by rcnut223, Dec 11, 2011.
  1. rcnut223
    rcnut223
    from wisconsin
    Caveman
    Took most of 6 months off, didn't touch a thing .
    Burn't out and missed a deadline I had set for myself on the unchopped car.
    Have been going at that car pretty hard since Christmas
    Changed my mind Ina number of things during the break
    The chopped car will be black and fender less
    The unchopped car will be fendered and use the original frame
  2. Outback
    Outback
    from NE Vic
    What Cavman said ^^X2^^!
  3. rcnut223
    rcnut223
    from wisconsin
    ImageUploadedByH.A.M.B.1421638832.776987.jpg while tearing into the drivers door I noticed that their was a lot of lead around the hinge
    Also the door just isn't fitting right .
    I removed the lead a found this
    kidcampbell71 likes this.
  4. wow its been awhile I almost forgot I subscribed to this thread , rock on man!
  5. rcnut223
    rcnut223
    from wisconsin
    Thanks guys
    Feels good to be back at it !
    tmfcracing likes this.
  6. Keep it moving.......
  7. big duece
    big duece
    from kansas
    I know what you mean about taking time off and regrouping your thoughts. A second deuce on your hands doesnt help matters. The first one starts to get jealous.
    kiwijeff likes this.
  8. rcnut223
    rcnut223
    from wisconsin
    Your killing me man
  9. rcnut223
    rcnut223
    from wisconsin
    ImageUploadedByH.A.M.B.1421717775.492834.jpg the hinge area has been hit at some point
    This area should be straight
  10. rcnut223
    rcnut223
    from wisconsin
    ImageUploadedByH.A.M.B.1421717903.676649.jpg i drilled out the hinge rivets and the 2 positioning welds on the hinge half attached to the door
    Here's what I found
    Argh
  11. Mart
    Mart
    The hinge area can get damaged like that from the door getting blown open on a windy day with no check strap in operation, or reversing with the door open and catching the door on something, or another scenario is wrenching the door open on a body that has been sitting for years and the hinges have seized up. there may be other causes, but that damage is quite common. My sedan has hinges damaged like that.
    Mart.
    kidcampbell71 and loudbang like this.
  12. big duece
    big duece
    from kansas
    Most guys would be feel honored to have those problems.:cool: With your talents, I am sure you will get through it.
  13. greaser
    greaser
    A lot of us have this same door hinge damage. Looking forward to see how you fix it!
  14. rcnut223
    rcnut223
    from wisconsin
    ImageUploadedByH.A.M.B.1421814661.524367.jpg ImageUploadedByH.A.M.B.1421814675.073898.jpg
    Well I did not get a picture while I had the hinge in the vice... Hmmm
    So I've drawn the method I used
    I simply placed two blocks on one side of the hinge and a small block on the outward side of the bend and tightened
    No need to over bend , this is not hardened metal
  15. rcnut223
    rcnut223
    from wisconsin
    Mort
    You are correct . In this case , my guess and only a guess, from the looks of the skin and the fact that the upper has no damage, is that the car drove into something .
  16. rcnut223
    rcnut223
    from wisconsin
    Before removing the hinge I made straightened the area as much as possible , with the goal to get the door edge straight.
    I also made a pattern of the metal to be cut out
    And made the cuts
  17. rcnut223
    rcnut223
    from wisconsin
    ImageUploadedByH.A.M.B.1421968792.297306.jpg this slice allowed me to pull the door edge
  18. rcnut223
    rcnut223
    from wisconsin
    Here is the patch
    mgtstumpy and tmfcracing like this.
  19. rcnut223
    rcnut223
    from wisconsin
    ImageUploadedByH.A.M.B.1421970561.479833.jpg welded in place
  20. I couldn't stand it having two of them things. I'd have to build on chassis and switch bodies back and forth. Remember the '32 chevy roadster/'67 camaro that R&C did an interchanging body on?
  21. greaser
    greaser
    Great work as usual, Mike. You always make it look so damn easy... makes me think even I can do it!
  22. rcnut223
    rcnut223
    from wisconsin
    ImageUploadedByH.A.M.B.1422801875.519922.jpg ImageUploadedByH.A.M.B.1422801932.102724.jpg
    Returned last week from LA where I attended the LA Roadster show!
    My wife , Becky, and I met up with friend Martin Lundqvist and his wife Mia
    Here's a few shots of Martin's car ....wow!
    Had a great time! Wonderful to be in warm So Cal!
  23. rcnut223
    rcnut223
    from wisconsin
    ImageUploadedByH.A.M.B.1422802459.402425.jpg Here was my favorite !
  24. rcnut223
    rcnut223
    from wisconsin
    ImageUploadedByH.A.M.B.1422802505.985921.jpg ImageUploadedByH.A.M.B.1422802521.335433.jpg
    Caution
    Non Hamb material! Ha, ha
    Yesterday helped my son with the replacement of the sub rails on his 270z . We made new ones a while back when we discovered damage from a previously acceding that was poorly repaired .
  25. rcnut223
    rcnut223
    from wisconsin
    ImageUploadedByH.A.M.B.1422827662.190104.jpg ImageUploadedByH.A.M.B.1422827696.856902.jpg ImageUploadedByH.A.M.B.1422827723.657346.jpg ImageUploadedByH.A.M.B.1422827789.023546.jpg
    Bottom of the door was decent on the inside with rust on the inside contained to one end . Decided to make the pieces rather than buy
    Here's a few pictures
  26. rcnut223
    rcnut223
    from wisconsin
  27. Proof positive that one can make chicken salad out of chicken sh*t!
    beautiful work! HRP
  28. rcnut223
    rcnut223
    from wisconsin
    Rushed the panel install, ImageUploadedByH.A.M.B.1422967644.689816.jpg ImageUploadedByH.A.M.B.1422967734.508745.jpg pushed the bottom of the door up to much when installing the outer panel and the bottom is a bit short
    Cut a seam in the door patch and welded it to the correct length
    Last picture shows the finished product on the car
  29. big duece
    big duece
    from kansas
    That's craftsmanship right there. Faced with a challenge, hit an obstacle and finding a solution.
  30. rcnut223
    rcnut223
    from wisconsin
    Thanks Greg
    It was Dinner time and I wanted to get the panel hammered down and and shop cleaned before I went in. Did no pay attention to the measurments...oh well a couple hours wasted again.
