Rust removal in the future
Discussion in 'The Hokey Ass Message Board' started by Devin, Jan 4, 2015.
  1. Devin
    Devin
    from Napa, CA
    Just stumbled on this video:
    Looks like surface rust only and wouldn't work for seams etc. but still pretty fricken cool none the less.
  2. If it works, E.P.A. will outlaw it soon.
    ct1932ford and fourspeedwagon like this.
  3. jetnow1
    jetnow1
    from CT
    1. A-D Truckers
    Not true- they just will outlaw everything to cover it to prevent rusting!
  4. Devin
    Devin
    from Napa, CA
    Out here water will be outlawed to form rust in the first place.
  5. Do you know what the process is? apart from damn cool. JW
  6. pitman
    pitman
    Any clues as to how ferric and ferrous are sent packing?
    (Sibley's molasses vapor gun?) ;)
    kiwijeff likes this.
  7. aircoup
    aircoup
    That's cool
  8. Bam.inc
    Bam.inc
    from KS
    Source: Laser Cleaning with High Power Short Pulse Laser: "Laser cleaning is a process that removes scale, oxides, dust and oil from materials. Using a short-pulse laser, the surface is cleaned to the bare metal quickly and with minimal heat affect. It can be an in-line or batch process performed directly prior to a process that requires a clean, bare metal surface. The fiber delivered TRUMPF TruMicro 7050 accomplishes this with a laser power of 750 watts and a pulse duration of 30 ns."
  9. Bam.inc
    Bam.inc
    from KS
    Just guessing that machine that cleaned off something the size of a hinge is the size of a minivan & $100,000+++.
    Better get blaster, discs, or molasses out... b/c we I will be over 100yrs & model A will be 150yrs b4 we're lasering off rust in our hobby shop.
  10. pitman
    pitman
    Did wonder about the heating of say, a sheetmetal surface...
  11. VOODOO ROD & CUSTOM
    VOODOO ROD & CUSTOM
    Calling George Jetson to the Blast Room !
    VR&C.
  12. gnichols
    gnichols
    from Tampa, FL
    [QUOTE="... fiber delivered TRUMPF TruMicro 7050 accomplishes this with a laser power of 750 watts and a pulse duration of 30 ns."[/QUOTE]
    Oh yeah? I can delete that rust in just 27 ns. Gary
  13. Devin
    Devin
    from Napa, CA
    Yup. For now all I have is my 10 year old craftsman angle grinder and a wire wheel but it's cool to dream!
  14. blowby
    blowby
    from Nicasio Ca
    I need one of those big enough to move a whole car through. Like a car wash. With primer guns at the end.
  15. GEGE
    GEGE
    salt.jpg Here is another recent way to get rid of rust.
    Have not tried it but maybe someone should?
  16. I guess that's what we will use when the EPA bans sand blasting.o_O HRP
  17. Devin
    Devin
    from Napa, CA
    That's cool. If like to try that. I by it's relatively inexpensive and since it's already used in our water systems disposal should be safe and easy.
  18. Doesn't throw enough sparks to suit me or any of the TV shows.
  19. gonmad
    gonmad
    I'm gonna bump this to see if anyone else has any input of how it works (lay mans terms) and what it costs?
  20. Mr48chev
    There has been a video of a laser rust/paint removal setup floating around FB for the past couple of weeks.
    This one. I'd imagine that the equipment is quite spendy at this time.
    If it doesn't show a rusty panel with slots in it sitting on a work table hit the refresh button on the bottom of the video.
  21. 26 roadster
    26 roadster
    as shown in the video above $450,000.00
  22. gonmad
    gonmad
    Wowza!!
    So next q, how does it actually work?
  23. Beanscoot
    Beanscoot
    Yeah... for starters, both videos showed other than sheet metal. The first is about 1/4" thick steel, the second is cast iron.
    Is the rust really removed, or just the colour changed? How is the cleaned surface for painting?
    It sure looks cool.
  24. gimpyshotrods
    gimpyshotrods
    You can get a little backpack one for just $80k.
    Traditional?
  25. There was another thread on this last week.
    At almost 500K, I'll stick with molasses and blasting.
