Hot Rods Rumble in front end during low speed turns
Discussion in 'The Hokey Ass Message Board' started by Shawn Wildman, Aug 19, 2021.
  1. Shawn Wildman
    Shawn Wildman
    The front end of my 1941 1/2 ton truck is making a low rumbling noise during low speed turns. I'm talking like driveway/parking lot speeds and almost any amount of turn in the wheel. It sounds like the tires are rubbing, but I have confirmed that both tires are completely clear of any obstruction lock to lock. I can't hear the rumbling noise at any other speed, but that could be from all of the other wind/exhaust noise. Turning the steering wheel at any speed is a chore, but the stock steering wheel was replaced by the PO with a 15" wheel. I checked all of the bolts in the front end to make sure they were tight simply because I didn't install them and I don't typically trust PO's.
    The front end is
    • 4" drop axle. Rear is parallel leafs with a 4" drop.
    • I'm running bigs and littles, not sure of tire sizes.
    • Split wishbone radius rods.
    • Stock spindles
    • Stock steering box and linkages. PO rebuilt the steering box. Seems too tight to me.
    • 39' Lincoln front manual drum brakes.
    Any help is appreciated. Thanks.
  2. Check the wheel bearings. Could be too tight/too loose, worn out or need grease.
  3. greybeard360
    greybeard360
    Are the tires feather edged? Have uneven tread wear at the edges? As stated above... Wheel bearings.
    427 sleeper likes this.
  4. BJR
    BJR
    X3 wheel bearings.
  5. lostone
    lostone
    from kansas
    X4 wheel bearings
  6. Shawn Wildman
    Shawn Wildman
    I’ll check them and see. Thanks.
