Hot Rods Rich's Coupe - a ten year odyssey
Discussion in 'The Hokey Ass Message Board' started by Rich B., Nov 10, 2019.
  1. Rich B.
    Rich B.
    from Portage,IN
    I drug this home in April of 2008 , hard to beleive it was that log ago ! I was in no rush
    to build it, needed some thing to keep me busy. It was pretty rough, but the price was
    right. It was out of state (just over the line in ILL) but requiers vin check. A call to the
    Lil'Alb, Dave Mc, scotty t and 9 others like this.
  2. Rich B.
    Rich B.
    from Portage,IN
    I got a xtra set of doors, one good fire wall, and real rough set of fenders. coupe2.jpg
  3. Rich B.
    Rich B.
    from Portage,IN
    Has quite a bit of bondo, and the bottom 6" is full of pin holes. in other words normal. coupe3.jpg
  4. Rich B.
    Rich B.
    from Portage,IN
    I mounted the body on my frame jig and braced the inside of the cab to keep it square.
  5. Rich B.
    Rich B.
    from Portage,IN
    I first removed the center section of the roof, and removed the T molding by cutting althe spot welds.
    I than reinstalledd the panel adding washers to make up for the molding. coupe6.jpg
  6. Rich B.
    Rich B.
    from Portage,IN
    Well that was fast! I lost a bunch of pics in computor crash!! Oh well it's pretty
  7. Rich B.
    Rich B.
    from Portage,IN
    I only took 2" out as I'm tall and like the head room. I think it helps the look of the profile also. coupe8.jpg
  8. Rich B.
    Rich B.
    from Portage,IN
    It really cuts down on warpage the lower you make the cut.
    Have ground all welds including alll door poosts.
  9. Rich B.
    Rich B.
    from Portage,IN
    while the doors were off I replaced all the hiinge pins with over size stainless pins . also replaced the
    Little did I know this would come back to haunt me !
  10. Rich B.
    Rich B.
    from Portage,IN
    Here's the center roof panel after blasting ready to have the T molding tacked back
    in after cutting 2" off the end. See you don't have to cut it in the middle ! Actually
  11. Rich B.
    Rich B.
    from Portage,IN
    I cut the gas tank out, and filled the feed hole. I have set up the other side of my shop
  12. Rich B.
    Rich B.
    from Portage,IN
    After the chop I pulled the entire car apart to blast all panels. the pics
  13. Rich B.
    Rich B.
    from Portage,IN
    I stored all pieces in my family room while working on one part at a time. coupe15.jpg
  14. Rich B.
    Rich B.
    from Portage,IN
    I braced the front cowl section, and cut off the rear sub frame. I repaired the edge off the
    firewall which was a real mess. Also repaired bottom of the cowl. coupe17.jpg coupe18.jpg
  15. GordonC
    GordonC
    Looking good! Keep it going!
    kidcampbell71 likes this.
  16. Rich B.
    Rich B.
    from Portage,IN
    Thank's Gordon !
    The replacement rails did not line up very well, so I ended up making a finger joint
    which is stronger any way. I fabbed the cross pieces from 16 gauge CR . The condition
    of the old sub frame shows the actual amount of rust I'm determined to get rid of.
    coupe20.jpg coupe16.jpg [ATTACH=
  17. That's where it was the first time I saw it!
  18. Rich B.
    Rich B.
    from Portage,IN
    Here's the cross members for the sub frame, and a view of the finished piece.
  19. Rich B.
    Rich B.
    from Portage,IN
    I had planned on preinstalling all the wood, but I had it in and out many times.
    I did stain, and poly urathane all the wood.
  20. Thor1
    Thor1
    Wow!, that looks really nice!
  21. Rich B.
    Rich B.
    from Portage,IN
    Starting to look like a car again , believe me it took longer to get this far
    than pics make it look! Lol
  22. Rich B.
    Rich B.
    from Portage,IN
    Anotherview, also tacking in that T piece.
  23. Rich, I wish I had met you when I was in my twenties. Maybe I could have learned some craftsmanship from you. Instead I’m a lazy hack in my 50’s !
  24. Rich B.
    Rich B.
    from Portage,IN
    This pic shows the new Brookville trunk lid, and lower panel. The latch hole was off center,
    the latch would not fit in the lid, and the mounting holes were off. The lower panel had no curve
    to it, and the deck lid was wavy in several spots. other than that everything was normal.
  25. Rich B.
    Rich B.
    from Portage,IN
    The above pics do not show the porta power used to adjust lid gaps. Also
    the time it took to curve the lower panel with my trusty shrinker stretchers.
    This pic shows the good firewall installed for body intgrity. I repaired the firewal edges
    and welded 1/4 20 nuts to the backside. I had to fill in all the old spot welds. I spaced
    all the attachment holes to match the upper cowl panel. Iwant this firewall to be
    removable as I have plans for this area.
  26. Deuce Daddy Don
    Deuce Daddy Don
    You are a real CRAFTSMAN!
    48fordnut, kidcampbell71 and scotty t like this.
  27. manyolcars
    manyolcars
    I love the step by step pictures.Keep'em coming. A 2" chop is smart. 6 inches is insane. Excellent cuts!
  28. Rich B.
    Rich B.
    from Portage,IN
    In the previous pic every thing looked fine, well it wasn't ! This is many weeks later, and
    the body is on the frame, and the frame is on the jig. I repaired the front mounts by
    the cowl, and fit all the wood body mounts. I also attached the wood blocks to the
    body so that I can remove, replace body easily. The visor does not fit for crap. coupe34.JPG
  29. Rich B.
    Rich B.
    from Portage,IN
    Iv'e had that wood header out more times than I care to think about ! All the wood is in the cab now.
    I'm finally commited to welding the visor to the roof. There are a couple steps at leading edge
    by the visor that I hammered flat, also some relief cuts to have smooth transition for the
  30. Rich B.
    Rich B.
    from Portage,IN
    Been awhile since I done any leading, but still remember how, showing my age now .lol
    I have seen too many Model A's with cracks in this area, so there will be no bondo here!
