Removing rust!
Discussion in 'The Hokey Ass Message Board' started by BLUDICE, May 27, 2011.
  1. BLUDICE
    BLUDICE
    I need a little advise here. I bought these really cool hub caps (old style) at a swap meet last weekend to put on my shoebox. They may be after market stuff - don't know for sure, but they are stainless with a couple of pot metal parts on the them. Well the stainless has some really tuff surface rust on them that won't come off using a rust removing gel, steel wool, or rubbing compound. The lighter rust comes right off with the steel wool. Sorry I don't have a camera to show you the caps. I have read something in Rod & Custom about using a battery and other stuff in a tank or what ever. Please help - thanks
  2. borntowrench
    borntowrench
    Stainless steel doesn't rust. Try the search function, there are many rust threads full of info for ya.
  3. Mudslinger
    Mudslinger
    Low grade stainless will rust. The aftermarket caps are made from a low grade mix and the steel mixed in the stainless type is whats rusting.
    It just depends on the grade used and most re-pop crap is that. The only thing that will fix them probably is sandblasting and having them chromed.
  4. CharlieLed
    CharlieLed
  5. chaddilac
    chaddilac
    The key ingredient in Stainless is Chromium, 18% is usually the high grade stainless, chinese stuff is much less. The chromium only slows down the rusting process, it doesn't eliminate it!
    I'd take em down and get em chromed! that'd be the best option!!
  6. BLUDICE
    BLUDICE
    I might just try the electrolysis thing - which would be quicker electrolysis or vinegar
  7. 3wLarry
    3wLarry
    from Owasso, Ok
    ask me about vinegar...:)
    kidcampbell71 likes this.
  8. BLUDICE
    BLUDICE
    yea, I read your thread on the vinegar, but in the long run was you OK with it??
  9. 3wLarry
    3wLarry
    from Owasso, Ok
    yep, but the wheel flash-rusted 30 minutes after I pulled it out of the soup. Gonna hafta redip it and primer it immediately after rinsing.
  10. shinysideup
    shinysideup
    from ruskin, fl
    Better yet use "metal ready".
  11. stainless steel is non-magnetic.
  12. mr.chevrolet
    mr.chevrolet
    300 series SS is non-magnetic, 400 series is magnetic
  13. tig master
    tig master
    from up north
    Nope
    The ferritic and martensitic stainless grades ('400' series) are generally free from austenite, have high permeabilities and so will attract a magnet. They are classed as ferromagnetic. These steels can be magnetised in an electric field and so can be used for electric solenoid cores, where good corrosion resistance is required. An example of this type of steel is the "soft" ferritic 430 (1.4016). :D
