Hot Rods Red Oxide Primer
Discussion in 'The Hokey Ass Message Board' started by Drew Link, Jul 28, 2016.
  1. Drew Link
    Drew Link
    I have done a search for this but didn't really find anything I was looking for. I have a 27 T Coupe and it has had red oxide primer applied to it sometime in the last 90 years! Can I prime over it with epoxy after roughing it up or do I need to take it to bare metal then start over? The final color will be flat black.
  2. squirrel
    with the rust showing through the primer, yeah, you want to strip it to bare metal. Won't take much, is my guess.
    Drew Link likes this.
  3. el Scotto
    el Scotto
    from Tracy, CA
    If the final color is flat black why not do it in flat black primer to begin with?
  4. Take Jim's advice,red oxide primer is just that a primer,it doesn't seal so the metal under the primer is rusty.
    I would suggest sand blasting. HRP
  5. The red primer is probably sprayed over 100 year old paint, rust, and who knows what.
  6. DDDenny
    Drew
    Pretty hard to argue with a guy that goes by HOTRODPRIMER.
  7. jcmarz
    jcmarz
    from Chino, Ca
    Leave as it is, that's great patina:p
  8. indyjps
    indyjps
    Buff it and see what happens, might be cool looking.... or just shiny pink.
    Strip it down and start over, it hasn't kept the metal from rusting.
  9. DDDenny
    Edit
    Saying this with the utmost respect Danny
  10. chopolds
    chopolds
    from howell, nj
    1. Kustom Painters
    Get rid of it,, as others said, primer is porous and could have rust underneath. It could have also absorbed many contaminants, and oils over the year, and cause paint adhesion problems. Sanding will not remove them.
  11. Drew Link
    Drew Link
    Thanks all. I guess I will get everything ready and take it to the blaster.
    Sent from my STV100-3 using The H.A.M.B. mobile app
    tb33anda3rd likes this.
  12. A Boner
    A Boner
    Hope you are not going to chop it!
  13. Drew Link
    Drew Link
  14. NewGuyOldFord
    NewGuyOldFord
    I absolutely love the "TALL" T's. Seems like with all the chopping, the term "TALL" is soon going to be a thing of the past.
  15. geoford41
    geoford41
    from Delaware
    Locate a "Dustless Blaster" they use a combination of grit and water with anti rust properties that keeps the warping to a minimum or not at all, the water cools the metal and with the correct pressure & angle of the nozzel you will have clean sheet metal that is not warped or "work hardened" I have had good results on my '40
  16. A Boner
    A Boner
    Any up to date pics?
  17. Drew Link
    Drew Link
