I found this in my oil pan. It's a piece of piston #5. Do I need to rebuild? Can I just replace that piston? The motor seamed to be running fine, 'till it started running a little rough. After checking timing, and spark plugs, I removed the rocker covers and noticed one rocker wasn't moving, at all. Turns out I had a bad lobe. I have a cam coming in the mail and decided to pull the whole thing out, clean the engine bay and freshen up the engine with paint and new gaskets. That's when I came across what's in the picture. It wasn't on top of all the gunk at the bottom of the pan so it seams like it happen years ago. Thanks in advance, fellas. Art.
Can you say Piston Slap ?? Rebuild it all do it right the first time . I would have to say to much piston to wall clearence machine the block and buy over size pistons
if your piston is bad, and your cam is bad i'd venture a guess that just about everything else is worn.
You don't say, but I am assuming it is a SBF I have seem a veiw of them with piston chunks in the bottom.
My dad's 65 Galaxie 289 cracked a skirt when it was still under the new car warranty, and my Boss 302 cracked all 8 of them. Must be a Ford thing
LMAO! Almost a whole piston skirt in your hand and you're asking if it needs a rebuild. Yes, it needs a rebuild. The shiny edges on those broken bits mean that those parts have been getting chewed on for God knows how long. Where did all that metal go? I'd bet money that 100% of it went through your oil pump at least once. Rebuild the entire engine and just thank your lucky stars that the bits in your hand do not include chunks of connecting rod and engine block.
That makes a lot of sense but, I'm looking at a rebuild kit at around $2k. That's just parts and gaskets, plus machine shop costs? That's if I do the work, and I'm not that confident. I was hoping somebody here had some other words of advice. Obviously, I'm not a mechanic.
Well, you can always temporarily park a small block Chevy in there for a while. They're cheap and mount kits are everywhere.
I know it sucks and parts are expensive for those but you will spend that twice in labor and parts if you try and patch the problem. It definitely needs to be rebuilt...just pray like hell no other ghosts come out of that closet when you get it to the machine shop. Good luck man
If you short on cash,it might be time to replace the hemi with a sbc or sbf,,,way cheaper than a Hemi rebuild kit. HRP
If it runs good, ??? run it. You might get another engine, put it on the stand and start rebuilding it, while your cruising your car. I will say, There is a rebuild in your future either way...
Plan B is a SBF or SBC. It ran o.k. but, with a ticking noise. I thought it was the valves. Apparently it was a piston slapping around in the cylinder like Jamoke had mentioned. X(
Good idea,...Bolt in a replacement, and rebuild your ailing motor as $$ is available. Item one, ought to be taking the stripped block to the machine shop, have them "tank" it and get an evaluation . Well worth the time, $ and effort. 4TTRUK
Not knowing a whole lot about old Hemis, cound the piston be installed the wrong way on the rod? That could break a skirt. Bob
I can't tell what made the skirt break. My Pops was a master mechanic, that's how I know a little about cars. He told me the motor had never been rebuilt. Unless it was assembled wrong from the factory. Like I said, I'm not a mechanic.
We COULD tell you what you want, but SHOULD tell you what you need. Tear it all the way down ,measure ever thing and hollar at us again. If that one broke, that only leaves seven to go. Which will be first?? Ben
